[TX] lt1 parts lt1 swap parts
Old Dec 18, 2010 | 06:33 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
dfw area
for sale, lt1 or lt1 swap parts all these parts are in used condition, known good parts from 94 firbird or 94 z28
-lt1 alum heads ported & decked with comp dual springs, titanium retainters, chromoley lash caps, 7* locks chromoley, new valve seals, 2.00"and 1.56" manley swirl polish under cut stainless valves and bronze liners, never run only installed - 400$
-comp cams solid roller for lt1, 112 lsa, @.050 230-236, lift .555-.565, meant for free flowing mild lt1 autocross with lots of mid range power - 100$
-matching ported lt1 complete intake, rebuilt over bored tb, svo 30# injectors, this things is clean had vatted after porting, has block off plates already, has alum tb cover that says z28, looks really cool, can throw in areomotive fpr also. bolt on a go make you lt1 breath better - 220$
-lt1 ecu and wire harness from a 94 formula firebird v8\m6 with two printed off diagrams of the harness - 50$
-lt1 engine block 30 over preped was assembled but never ran 2 bolt mains, save money on your rebuild and start with this block - 125$ no shipping...
-keyed crank hub lt1 - 50$
-lt1 oil pump drive gear shaft - 15$
-new lt1 timing gear set - 40$
-lt1 timing cover with new seals - 30$
-drive belt tensioner and bracket - 20$
-radiator, fans, harness with adjustble temp and relay, and both hoses - 200$
-crank pulley - 15$
-ps system modified to work on a thirdgen includes pump, res., and 4 hoses one was repaired and made longer to reach the steering box - 75$
-opti spark dist, plug wires, and opti harness - 125$
-short ram air intake, metal elbow, boots, clamps, filter, and maf - 125$
-coil and wire - 25$
-alt - 25$
-ac delete pulley, new - 40$
-water pump, new but painted - 85$
-94 lt1 piston rod rings
-94 lt1 head bolts
-lt1 cam 94, cam retainer, two big gear timing gears, two timing chains
-94 lt1 throttle body - 15$
-94 lt1 timing cover old seals - 10$
pics are here at the bottom http://www.cardomain.com/ride/263438...irebird/page-1
pm me if you want to buy any thing. we can talk prices, shipping, and more pictures in pm's. i have more stuff to be listed up as i get it out of the car.
Last edited by blackgold84; Jan 4, 2011 at 03:04 PM. Reason: add more parts to list
Old Dec 19, 2010 | 11:48 PM
Engine: 350ci
Re: lt1 parts lt1 swap parts
ttt
Old Dec 20, 2010 | 12:19 PM
jokertwink's Avatar
Car: 91 Camaro RS
Engine: 305tbi in process swamp 96 LT1
how old was the ps? also the kn filter?
Old Dec 20, 2010 | 11:35 PM
Engine: 350ci
k&n was never run
ps system is 94 firebird orig with 100k never had a problem with it, i owned the car it came out of it was a known good part
Old Dec 22, 2010 | 02:17 PM
Engine: 350ci
more parts on list
Old Dec 22, 2010 | 02:51 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
interested in heads. who ported them?
Old Dec 25, 2010 | 10:10 PM
ch@0s's Avatar
interested in injectors .. and FPR
Old Dec 26, 2010 | 05:24 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Hello, I sent you a PM on the 20th and got no reply. I'm interested in the PS setup, the oil pump driveshaft, the new timing gear set(does this come with the chain?), and the Acc bracket. I may be interested in other things depending on how much these are, pm me a total shipped to 09139. It's an APO (same as shipping to New Jersey.
Thanks, Ken.
Old Dec 31, 2010 | 01:50 PM
Engine: 350ci
hello again, back from holidays... update on the heads, they will be sold complete. cam for sale as well.
heads are ported by me.
sorry for the delay on shipping & prices
would like to keep the injectors on the intake but make an offer, also which fpr are you asking about? stock or areomotive?
PS setup - 75$
oil pump gear drive - 15$
new timing gear set/with chain - 40$
Acc bracket - 20$
=150$+(shipping/cant find this zip code help me out here)
give me the full adress if you want a shipping quote and i go to the fed ex store and ask them?
Old Jan 3, 2011 | 08:51 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Pm sent
Old Jan 14, 2011 | 02:37 AM
caco_0101's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 5.0 TPI
Axle/Gears: Stock ?
Is the lt1 cam in good condition what u asking for it shipped to 78589? This is from a camaro z28 ? thanks
Old Jan 14, 2011 | 09:05 AM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
is the power steering and ac delete pulley still for sale if so how much shipped to 08527
Old Jan 16, 2011 | 10:34 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
FPR areomotive adjustable....how much shipped to 32962
Old Feb 3, 2011 | 05:43 PM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
Is the PS system still for sale? Also interested in the water pump (what color is it painted?). How much would shipping be to V0R 1N1 Canada?
midge54
Jan 29, 2017 07:00 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
