1987 IROC PARTOUT 350TPI/700R4/9-BOLT
Old Dec 28, 2010 | 08:21 AM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Parting out 87 IROC. it is a 350TPI/700R4/9-BOLT car. I am located in the Toronto, Canada area so I can ship small items at minimal cost but larger items normally cost a arm and a leg. So if you need something that is fairly light and will fit in a box smaller the 16x16x16 shipping will be very reasonable.
I will post some pics up later and if anyone want specific pics pm or leave your email adress and zip and I will get back to you asap.
Thanks, Josh
TPI Intake $200 ( SOLD )
165 ECM $125
TPI Engine Harness $125
9-bolt Complete with J65 Brakes $225 ( SOLD )
34/23mm Swaybar set $80
Front/Rear springs $60
Over head Console $60
083 Cylinder heads complete $75
350 short block 1 piece rear main seal roller block $125 ( SOLD )
starter $30
700R4 with converter $200 ( SOLD )
Front/Rear seats Deluxe Grey $225
GFX Panels $100
Nose cone $50
Headerpanel with lights $50 ( SOLD )
Fog Lights $125 ( SOLD )
3 piece wing $40 ( SOLD )
240 kph Gauge Cluster has 165xxxkm $125 ( SOLD )
Hood Louvers $80 ( SOLD )
85-87 16" Iroc rims $275 ( SOLD )
Wonder bar $30 ( SOLD )
Rad $50
Dual Fan set-up with shrouds and wiring $125 ( SOLD )
Spare tire Assembly $30
T-TOP bag $60
Quick Ratio Steering Box $50 ( SOLD )
Tilt Steering Column with key and vats box $75
Grid tail lights $60
center console upper/lower $100
Cruise control set-up $50
Power mirrors Complete with wiring and switch $60 ( SOLD )
Interior Harness $40
Fuel tank with Pick-up $50
Window motors $5 each
Door lock switches $5 each ( SOLD drivers side )
Various Harness connectors $5 each
Auto shifter $10
Park brake lever $10
Door trim plates $10 each
Rearview mirror with map lights $25 ( SOLD )
3rd brake light switch $10
H-Vac controls $20
Radio + H-Vac trim bezel $5
Spindles $50
Motor mounts engine/k-member side $30
Wiper transmission $10
Lots of small stuff as well.
Prices are or best offer. If you would like to get a hold of me by phone
416-436-5515
Thanks, Josh
Old Dec 28, 2010 | 09:00 AM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
Re: 1987 IROC PARTOUT 350TPI/700R4/9-BOLT
do u have a wonder bar?...not sure on the size of...
Old Dec 28, 2010 | 02:45 PM
Yes I have the factory wonder bar. 25 plus shipping.
LMK
Thanks, Josh
Old Dec 28, 2010 | 03:07 PM
SOLD
Hood Louvers
Rims
Interior plastics
Thanks, Josh
Old Dec 28, 2010 | 03:46 PM
Car: 1983 Z-28
Engine: 5.7 L
LMK
Thanks, Josh
ok thanks I'm very interested...do u have pics?...or is it still installed?...
here's my email Chevy0013@aol.com...
let me kno thanks...
Old Dec 28, 2010 | 04:23 PM
It is still in the car but I can pull it tommorow and snap some pics.
I need your zip so I can get a shipping quote for you.
Thanks, Josh
Old Dec 28, 2010 | 04:58 PM
Car: 1983 Z-28
Engine: 5.7 L
ok thanks......its 90650...
Old Dec 29, 2010 | 12:29 AM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Wondering about the diff..is it disc brakes? and what ratio?
Thanks,
Jon
Old Dec 29, 2010 | 03:39 AM
1bad92z's Avatar
Car: 1992 Z-28
Engine: N/A
Transmission: N/A
Axle/Gears: 373
Is the motor and tran's in good working order?
Old Dec 29, 2010 | 06:27 AM
Jon,
The rear is a 3.27 limited slip unit with the J65 Iron caliper disc option.
You would have to pick it up if interested since it would be a pain to ship.
Josh
regards to the engine it needs a rebuild and the tranny is good.
Old Dec 29, 2010 | 05:48 PM
The wonder bar is pending sale locally, If he does not take it within a week then 83C you have next shot at it.
Thanks, Josh
Old Dec 29, 2010 | 06:18 PM
Car: 1983 Z-28
Engine: 5.7 L
aww r u serious?...but den that's fine i guess...but plz let me kno if he doesn't take it...do have any pics?...
does the car have the spoiler with a 3rd break light?...
Old Dec 29, 2010 | 06:35 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Any chance you have the PROM chip(inside ECM) and the 22lbs fuel injectors? very Interested if price is right....
Old Dec 29, 2010 | 07:51 PM
Yes it has the 3rd brake light style spoiler.
I am not seperating the injestors and prom from the TPI system, Sorry.
Josh
Old Dec 30, 2010 | 12:09 AM
Car: 1983 Z-28
Engine: 5.7 L
how much would u sell the decklid with the complete 3pc spoiler?...with out the glass?...
Old Dec 30, 2010 | 06:24 AM
You are to far to ship something that size. It would not be economical.
Josh
Old Dec 30, 2010 | 09:02 AM
Car: 1983 Z-28
Engine: 5.7 L
yea that's true...let me kno if the wonder bar sells...
Old Dec 31, 2010 | 09:07 AM
SOLD
240/KPH Gauge cluster
PENDING
Quick ratio steering box
9-Bolt
3 piece wing and 3rd brake light
wonderbar
Old Dec 31, 2010 | 05:57 PM
SOLD
Steering Box
Old Jan 1, 2011 | 06:38 PM
hemi-killer's Avatar
Want a title? Post!
Car: 1986 IROC
Engine: 350 30 OVER 650 DP
Transmission: 700 R4
Axle/Gears: NEEDED
Can you post pics of the rear end.Thanks
Old Jan 1, 2011 | 07:15 PM
Rear end is to large to ship.
Josh
Old Jan 1, 2011 | 08:46 PM
Car: 1983 Z-28
Engine: 5.7 L
is wonder bar still pending?...
Old Jan 1, 2011 | 08:47 PM
Yes,
The gentleman is supposed to pick it up tommorow. If not you will have first dibs.
Josh
Old Jan 1, 2011 | 09:32 PM
Car: 1983 Z-28
Engine: 5.7 L
ok thanks...let me kno..
Old Jan 1, 2011 | 11:04 PM
1bad92z's Avatar
Car: 1992 Z-28
Engine: N/A
Transmission: N/A
Axle/Gears: 373
Is the motor and tranny still up for sale? If so, are they both in good running? Thanx for your time.
Old Jan 2, 2011 | 05:47 PM
SOLD
Fog Lights
sent you a pm regarding the wonderbar.
Thanks, Josh
Old Jan 3, 2011 | 12:00 PM
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Would you be willing to sell the ECM & prom separate?
Old Jan 3, 2011 | 12:41 PM
Not from the system off this car.
I do have one off a 89 IROC was A 350TPI/700R4/9BOLT car.
it is a 165ecm
100 plus shipping
Josh
Old Jan 4, 2011 | 06:33 AM
PENDING
Header panel
sway bar set
Sent pictures to all who requested.
Thanks, Josh
Old Jan 6, 2011 | 05:21 PM
SOLD
Wonder bar
Heater pipe
Shipped
Fog Lights
Speedo
Thanks, Josh
Old Jan 16, 2011 | 07:48 AM
TTT
Old Jan 17, 2011 | 07:42 PM
saxmo's Avatar
Do you have the OEM radio deck? If so, how much shipped to 77327? thanks
Old Jan 19, 2011 | 06:26 AM
105 shipped
Old Jan 21, 2011 | 12:27 AM
mikespeed's Avatar
Car: 87 IROC
how about the 4x6 speaker brackets? shipped to 92029?
Old Jan 21, 2011 | 06:24 AM
35 Shipped
Old Jan 22, 2011 | 06:26 AM
SOLD
9-BOLT
Dual fan set-up
PENDING
T-Top bag
Old Feb 21, 2011 | 08:14 PM
eflores's Avatar
Car: 91 z Clone
Engine: 6.4l LSX
Axle/Gears: s12 3.73
Do u still have the 083 heads? Shipping to 80817 on just a single head.....or both if u won't separate
Old Feb 21, 2011 | 08:50 PM
What side do you need?
lmk
Josh
Old Feb 22, 2011 | 09:40 PM
eflores's Avatar
Car: 91 z Clone
Engine: 6.4l LSX
Drivers side.....didn't realize they were different based on side
Old Feb 22, 2011 | 10:09 PM
speed.chad's Avatar
if you still have the 083 heads what's shipping to 36526
Old Feb 23, 2011 | 06:09 AM
A pair of heads due to the weight and that I am shipping from Canada is expensive. Shipping to 36526 is 100 bucks.
I could do 175 shipped but that is your call.
Josh
Out-Cast
Dec 31, 2015 04:40 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Out-Cast
Aug 17, 2015 10:57 AM
