[MO] Tpi oil dipstick needed!
Car: 87 GTA
Engine: Two cracked out gerbils
Transmission: 700r with a probuilt automatics kit
Hi,I am in need of the oil dipstick and tube for my 87 gta.Heck ill even settle for information on where i can buy a new one.Mr gasket has a 82-85 tube but its different than mine i believe it falls short of going through the stock windage tray.
Please if you have one pm me with price shipped to 64118.It dont have to be pretty just not rusted out.Thank you so much!
edit: its a l98 tpi 5.7
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: Tpi oil dipstick needed!
I have one that is in GREAT condition. The Tube is only about 6 years old, I bought a NOS one in 2004 when I did my engine swap. The stick is stock from 1989.
Check out the link for pictures.
https://www.thirdgen.org/forums/engi...-tube-dip.html
Kevin
Kevin
Car: 87 GTA
I don't think that's the right one.On my dipstick it is longer than that on the end where it goes in the block.After the lip that rests against the block my stock one is longer than that by the looks anyhow.I do believe that's 82-86..?
For some reason mine is longer at that point and if i try and use a shorter one the dipstick itself wont go past the windage tray in the oil pan.This is really odd that some of these dipsticks are different from nearly the exact same engines.I think maybe there are different revisions of the oil pan perhaps.Ill measure mine and post the length after the bump where it seats against the block.I just bought one from a guy on this site but im still not sure if its correct.Ill let you know.BTW thank you!
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Mine is from a 87 so lmk if the one you got does not work.
Josh
Josh
Engine: L98 350 TPI
If yours is an F-body L98, Roller block/one piece rear main, the dip stick/tube I have is the correct one.
It may look short in the picture I took but it is the right one.
maroe624
Apr 16, 2017 08:29 AM
