[LA] Fan controller, 3.23 gears, LT1 header gaskets
Old Jul 26, 2011 | 09:23 AM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
I have an adjustable fan controller that I used for a few months but swapped in a LT1 and use the PCM now. There is plenty on the leads to be reused. It will control two fans and comes with a little bracket I made. I have two sets of gears, both GM 3.23's. One set is a 7.6 and the other is a 7.5 set. Both in good shape. I also have a set of Percy's aluminum LT1 header gaskets. I used them for 5 minutes then pulled the motor due to a knock. I found they did not seal the tubes on my Dyno Don headers.
Fan controller $25 shipped
GM 3.23 gears 7.6: $50 shipped
GM 3.23 gears, 7.5: $45 shipped
LT1 header gaskets: $25 shipped
All shipping is to the lower 48. If you live outside the lower 48 you will pay a little extra for shipping.
Old May 13, 2013 | 03:36 PM
mikespeed's Avatar
Car: 87 IROC
Re: Fan controller, 3.23 gears, LT1 header gaskets
Series 2 or 3 on the gears?
NM. I fail!
Last edited by mikespeed; May 13, 2013 at 03:36 PM. Reason: fail,... didnt see this is a 2 year old post.
eightsixseven
Dec 16, 2024 01:50 PM
1984HO
Mar 19, 2021 11:59 AM
hectre13
Aug 26, 2015 08:17 AM
