Jeep Steering Shaft Upgrade
Car: 85 & 87 Monte Carlo SS/80 El Camino
Engine: 305/350/454
Transmission: 2004R, 2004R, TH400
Axle/Gears: 3:42, 3:73, 3:23
I have a few Jeep Steering Shafts for sale. $60 each Shipped USPS (lower 48 states).
These are compressed, cleaned, painted, greased and ready to install.
These shafts make a great upgrade over the old rag joint setup.
Tightens up the steering and gives more clearance along with a cleaner look.
I spend a lot of time getting them prepped and make sure the finished product is as good as they can be. The ones i sell are separated, cleaned, sanded and painted along with little extras like spreading them so they slide right on, cleaning the bolt threads, greasing them, etc....
When you get one from me it is 100% ready to install.
Send me a PM if your interested in one.
Video of the installation of these shafts.
This in not my video but its well done.
http://www.youtube.com/watch?v=28MVJxM5-l0
There seems to be some conflicting opinions on whether the "d" shaped part of the column needs to be notched or not.
Here is what I discovered about the upper "D" shaped section.
The upper "D" shaft on has a "Top" & "Bottom". These have 2 flats on the sides but the rounded sides are different also. The "Top" is rounded but the "Bottom" has a flat spot for the bolt.
I originally thought the shafts did not require a notch if you align the bolt with the flat spot on the top section. However after a few tests I realized a notch is required. The notch is also a good idea to prevent the coupling from sliding down off the shaft. If you notch the flat side, a smaller grove is required.
Hopefully this clears up the mystery and helps with the install.
Here are some testimonials:
Hey Ken, got the shaft yesterday. Packing was great and the assembly was all clean and painted black. So pretty!!! I hate to put it on the car now. I think i'll let it hang in the shed and accumulate some funk before i install it. Thank the the opportunity brutha!!
Ken, Thanks again setting me up with the Jeep Steering Shaft. I hadnt any luck finding one in the Bay Area (Calif). Im sure the shaft allowed me to beat my buddy(73 Corvette) at our Autocross events. Terry
Got mine within a couple of days. Cleaned and painted, and it was excellently packed. Can't wait to put it on.
Engine: 305/350/454
Re: Jeep Steering Shaft Upgrade
They work on the 3rd gen Camaro's, i would imagine the Firebird would be the same.
I don't have one to check, maybe someone will chime in to verify.
Engine: 305/350/454
Only a few left.
Engine: 305/350/454
I have had many questions about the notching of the shaft so i thought some more instruction may be in order.
The notch required for the bolt has to be made on your steering column shaft NOT the Jeep Shaft.
To make things easier i used an extra steering column for the pictures. The area you are seeing is the part of the steering column that comes thru the firewall.
This is what it looks like once you remove your stock shaft.
Slide the Jeep shaft on as shown.
If you look thru the bolt hole you can see where the column shaft sticks out into the opening.
Mark the center of the bolt hole with a marker.
I got carried away with my die grinder so the notch is larger then it needs to be.
Now you can see the bolt hole is clear straight thru.
Bolt installed and shaft locked in from sliding off.
Hopefully this helps.
Engine: 305/350/454
The last one i shipped to Canada was an extra $20 if i recall.
If you PM me the exact address i can let you know however i have a sale pending on the last one i have right now.
I may be able to get some more tomorrow but can't promise yet.
Engine: 305/350/454
Just got a few more today, this will be all for awhile since i wiped out all the yards in my area.
PM me if you want one.
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Pm sent w/payment
Engine: 305/350/454
Thanks Guys.
I will ship them Monday.
Engine: 305/350/454
Only a couple left.
Engine: 305/350/454
Shipped them to everyone today.
When you get them and if your happy with everything please leave me positive feedback.
I have 2 left ready to ship. most likely be all i will have for a while.
Engine: 305/350/454
I have 1 left, cleaned, painted, wrapped and ready for shipment.
Free Bump.. and Left you your First Feed back
Pm sent to you about Feed back alot of Guys dont take the time to Fill it out.
( i would be over (22) now..lol
Fast shipping nice Packing. and at a Price thats Nice.
Keep up the Good work
and
and
Car: 73RS, 85 Iroc, 11 GT
Engine: 383FI, 406 FI, 5.0
Transmission: TKX, TKO600
Axle/Gears: 10 Bolt 3.73s, Strange 12 bolt 3.73
Recieved the steering shaft, looks great
Thanks!!
Thanks!!
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
i would like to have the last one if ya still have it. willing to ship to APO via Priority mail?
Engine: 305/350/454
Car: 91 Camaro RS
Engine: 305 TPI conversion.
I just came across this. do you have one left? if not are you going to have anymore done in the near future?
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
also curious if you have any left or will have more. thx.
Engine: 305/350/454
Hope to get more today and tomorrow.
Shoot me a pm to get in line on the waiting list.
Engine: 305/350/454
Engine: 305/350/454
All on the waiting list accounted for.
I have a few more in stock.
Engine: 305/350/454
Got them all cleaned up, working on spreading them and cleaning the threads.
They will be painted this afternoon and ready to ship Monday.
All are spoken for except 2 so if you wanted one and didn't get a message from me send me a PM.
Remember these are 100% ready to install, i even test fit each one on a steering column so there are no surprises.
No guess on what the cost is, $60 shipped.
Engine: 305/350/454
Had a few that said they wanted them not respond so I still have a couple left, they are all ready wrapped and ready to ship.
Unless my local yard gets a bunch of new jeeps in this will most likely be all for a month or more.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I'm interested in one, but won't have $ into my Paypal for a week or so & with the holiday bills I'd be better able to afford it after the first of the year. I'll check back with you then to see if you have one.
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
this is awesome.. im curious indeed. never heard of this till now. i wonder if this could all be swapped out with basic hand tools?
Car: 91 Camaro RS
I received mine in the mail within a few days and it looked great. Just today I was able to get out there and get it installed. To answer a listed question, all I needed was basic hand tools. I did have to tweak the brake lines a little to get the stock shaft out, but the new one went in and bolted up without problems. Altogether it was about 30 min. of time.
A quick test drive and I can feel the steering much more solid. Well worth it!
Engine: 305/350/454
Great Tony, the difference is amazing isn't it.
Berlyn0963 i have 1 left not spoken for as of now.
I sell these on 7 different message boards so its 1st to PM me 1st to get it.
Let me know and i can ship it Monday.
Engine: 305/350/454
Please send me a PM, I will then put you on the waiting list and notify you when i get a new batch in stock.
received mine. been too busy to install it tho. thanks a lot!
Engine: 305/350/454
Engine: 305/350/454
Sorry i only sell them painted and ready to install.
Engine: 305/350/454
Sorry for the delay, if you would have sent a PM i would have got a notification and responded sooner.
PM Sent.
PM Sent.
Engine: 305/350/454
Sold the last one.
If anyone wants to get on the waiting list send me a PM and i will notify you when i get more.
Car: 1987 Trans Am
Engine: LQ9/L92
just wanted to say thanks, got mine last week. adding to the growing stock pile of spring time upgrades
Engine: 305/350/454
Glad you are happy Dan.
Looks like my local yard has a few more in stock.
I will go get them if anyone is interested.
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
i am interested. ill buy one now if you get another. are some more wore out than others?
Engine: 305/350/454
It rained last night so i didn't feel like playing in the mud today.
I will try to get there one day this week and see how many i can get.
I have 4 on the waiting list so far.
Please PM me if your interested so i can track them in the order they are received.
I don't get them if they are not in good shape.
I have only seen 1 so far that was not usable.
These are a really good design and really don't wear out unless they are subjected to some extreme use.
I have had 4 different ones on my car, 1 or each style including 2 of the ones with the cast ends and have not been able to feel any difference between them.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
They (Jeep and Astro van shafts) do, however, introduce considerable noise into the system--at least that's been my experience.
JamesC
JamesC
Engine: 305/350/454
I didn't notice any difference on my Monte SS as far as noise.
May be different on the F-Body but the Jeep shaft does have a rubber isolator so that should help it.
Since i no longer have my 86 IROC i can't test it to see for myself. I would be curious to find out if any others have noticed this.
As you can see above I like to be as informative as i can be in my sale posts so if this is a common occurrence in the F-Body i would like to know so i can make it clear to anyone interested in doing this upgrade.
I experienced significant power steering whine (when turning) wiith both Jeep and Astro van shafts.
EDIT: After considering, I'm not sure that 'whine' is the best term as that conjures up other problems. It's a 'rushing' noise that wasn't present with the OE shaft in place.
JamesC
JamesC
Engine: 305/350/454
Went to the yard today but was only able to get a few.
I have sent a PM to those on the waiting list.
If you sent me a PM and did not get a reply today its because i didn't get enough to cover all the requests.
I am working with an out of state yard to have them bulk shipped in to me. If anyone want to get on the waiting list please send me a PM so i have an idea how many i need to get.
Thanks.
Thanks.
