[CA] TBI stuff reaaallll cheap...sold the car...
Old Jun 26, 2012 | 12:30 PM
loudpedal's Avatar
Car: DAF
Engine: 3 cyl 2 cycle
Transmission: variable speed
Sold the car and have a lot of spare parts collected thru the years......EDIT
2 set 5235279 two injectors 40# for a 305" and a pod no p.r. $25 each set/2
2 each New pressure diaframs with misc t.b. gaskets $20 the lot
1 set Big block injectors 5235231 90# with pod and regulator cover $45 set
2 each Injector 5235279 40# just the injectors (305 ci) $20 both
2 each Injector 5235206 55# just the injectors (350 ci) $30 both
1 ea EGR valve GM, # 17088125 small block..SOLD.... $ 5
1 ea " " " # 17087201 " " $ 5
1 ea Throttle body stock 305/350 bare body w/ blades and shaft
7089062 A,S,J,C,F vacuum ports 88-90 Cam & Caprice& Bird $ 20
1 ea T.B. stock as above but 4 vac port (no S) all have good shafts
GM # 17118295 $20
2 ea Connector and rubber grommet for two injectors , pigtail 10" $3 ea
2 ea New melonized dist. drive gear 10456413 for roller or flat
tappet cam (steel or cast) common 1/2" shaft $ 15 ea
1 T.B. air horn , steel , 1" high no tube $10
1 T.B. air horn , steel, 2" hich no tube $12
1 T.B. Manifold, aluminum, good shape all threads good SBC pre
Vortec, GM # 10108449 $30
1 Used and good roller cam. Stock GM grind $15
1 GM roller lifter hold down tray $ 4
1 TB Delco distributor, Delco module, brass cap & rotor $25
1 TB Delco dist, new ET module, new pickup, SMP cap & rotor $25
1 TB Delco dist, NO module, has pickup, SMP cap & rotor $15
1 TB Delco dist body, shaft an gear only $7
1 set Standard Motor Prods brass cap DR468 & rotor new (al TBI-TPI) $15 ea
2 ea Gates K061010 Goodyear 4061010 Serp belt 101" Truck & Van new $10 ea
2 ea Tensioner pulley/arm assy. Goodyear 49208 new Blazer, Van,Truk $20 ea
2 ea Tensioner pulley only GY 49015 3 1/2" dia new Most GM $10 ea
2 ea Tensioner pulley only GY 49006 3" diameter new $ 10 ea
I can ship UPS or US Postal (which might be cheaper) . When replying, I need your zip code for UPS charges.
I only take U.S. Postal Money Orders.....or cash. Buy $100 and Ill pay the shipping (except the cam).
You can pm or.....mail to oneandout(at) att (dot) net.
or phone............7am to 11am M-F 5416494 in the 714.
Last edited by loudpedal; Jul 9, 2012 at 11:45 AM. Reason: adding your zipcode, more info
Old Jun 26, 2012 | 05:39 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: TBI stuff reaaallll cheap...sold the car...
Definitely interested in the EGR valve 17088125. Shipping to 78415? May be interested in other items but haven't researched to ensure they are compatible with a 88 Firebird 305 TBI.
Old Jun 27, 2012 | 10:24 AM
loudpedal's Avatar
Car: DAF
so far I am holding the following for 5 days for folks that are "thinking" and /or "sending $$"
both EGR valves
BB injectors and pod
Diaframs and gaskets (the lot)
Old Jun 27, 2012 | 10:27 AM
loudpedal's Avatar
Car: DAF
Antares 57
The egr valve will fit in a medium Flat Rate Postal box at $$11.75. There will be room for some other small parts also. Let me know.
Jb
Old Jun 29, 2012 | 06:05 PM
antares57's Avatar
pm sent
Old Jul 9, 2012 | 11:46 AM
loudpedal's Avatar
Car: DAF
Sold items updated.......
Bubbajones_ya
Jul 6, 2024 08:32 PM
BLK87Z
Sep 18, 2015 11:29 PM
Glowsock
Sep 11, 2015 11:09 PM
J.C. Denton
Sep 8, 2015 05:35 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
