[IL] Found
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
Found
Part Found Looking for a V8 tach from a 82-89 Camaro. Did a v6 to v8 swap and can't find a tach anywhere. Thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 82-89 Camaro V8 tachometer
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
I have but I have no means of calibrating the tach and I am not very familiar with replacing resistors. Thanks tho
Engine: Lb9
Transmission: M20
if you don't want to use a couple dollar trim pot you might pm user rcar7395 he may have a v8 tachometer.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I've got one. PM or email me your email address for pics and other info, Henry
Or I have a whole 145 mph cluster, but that would be more costly
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
I believe I have a couple in the attic .. if the others don't pan out let me know ...
~DaVe
~DaVe
Engine: Lb9
Transmission: M20
Re: Found
not sure If you bought one yet. Rcar7395 said $40 shipped if you are interested.
Abubaca
Nov 5, 2016 12:22 PM
rudolphschenker
Sep 4, 2015 02:41 AM
