Moates programmer adapter and chips
Old Nov 13, 2012 | 09:34 PM
TPIEM240Z's Avatar
I have a Moates Burn 2 programmer, 3 chips and the ZIF GM adapter up for sale. All parts worked great prior to removal. Includes USB cable. Asking half or retail at $75 OBO. Likely have a few different setups still on the chips but would NOT recommend anyone use them.
Drop me a line.
-Mark
720-883-8885
Old Nov 14, 2012 | 12:10 PM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Axle/Gears: 4th gen 10 bolt 3.42 posi
Re: Moates programmer adapter and chips
Drop me a line.
-Mark
720-883-8885
Is this everything needed to burn a chip in a 91? If so, I'm interested. Do you have part numbers or links for the chips & adapter?
Old Nov 14, 2012 | 06:02 PM
TPIEM240Z's Avatar
The chip adapter is here and includes two chips:
http://www.moates.net/gp1-package-gm...h-2-chips.html
The third chip is the same.
The burner is here:
http://www.moates.net/burn2-flash-n-...rogrammer.html
To burn a chip you will also need software such as TunerProRT which is what I used and have the right bin or program for the chip itself. This is all the hardware you would need including the USB cable.
-Mark
Old Nov 14, 2012 | 06:33 PM
budfreak1's Avatar
The burner is here:
-Mark
Thanks Mark.
I am the one who has been texting you today. I just need until tomorrow evening to see if I can figure something out, and even if I don't, I'll probably break the bank anyway to get it.
Old Nov 15, 2012 | 12:37 AM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
If budfreak1 doesn't take it then I will.
Old Nov 19, 2012 | 11:40 AM
budfreak1's Avatar
Received today, thanks alot man, looks great.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
InfernalVortex
Apr 20, 2021 11:31 AM
jaridjohn
Oct 5, 2015 07:01 AM
dusterbd
Sep 29, 2015 08:40 AM
