[GA] L-98 355ci, Scat rods & crank, Hedman headers, etc..
Old Sep 10, 2013 | 01:20 PM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
I have a ton of parts that I need moved from my garage asap to make room for my winter LSX conversion. I have a L-98 350 from my 89 IROC-Z, was machined last summer at Riverside Engine Machine in Charleston, TN. Bored 30 over, brass freeze plugs, clevite cam bearings. Has brand new Scat rods, crank and Speed Pro flat top pistons. New LT4 hot cam still in the block, Lunati roller lifters. 883 TPI heads with 550 lift springs, valve job completed last summer as well. Includes Oil Pan, brand new timing cover, New in box XR276HR Comp Cam, MSD Coil, Summit plug wires, Hedman coated mid length headers with O2 sensor, Aluminum bowtie valve covers. All of this for $500.00
This motor has approx. 10,000 miles and was driven most of the fall last year. I installed a high volume oil pump, which according to the machine shop was defective. It put out over 100psi under throttle... pushing oil past the rings... so they never seated. Everything is fine, bearings looked great when I tore it back down. It just needs a standard oil pump and some new bearings, rings, rockers and a timing chain to be complete again. Priced for a quick sale... my loss is your gain. PM for my contact info. I'm in Chickamauga, GA... which is about 15 minutes south of Chattanooga, TN.
WILL NOT SHIP! Local pickup only.
Attached Thumbnails L-98 355ci, Scat rods & crank, Hedman headers, etc..-l98.jpg
Old Sep 10, 2013 | 01:52 PM
blakerose's Avatar
Re: L-98 355ci, Scat rods & crank, Hedman headers, etc..
WILL NOT SHIP..... :-(
valve covers and headers please!
Old Sep 10, 2013 | 01:57 PM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Where are you located?
Old Sep 10, 2013 | 02:15 PM
blakerose's Avatar
Waterloo Iowa. PM me if you change your mind
Old Sep 15, 2013 | 10:16 AM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Sold
Ducati900ss
Sep 2, 2015 09:05 AM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
