[NJ] HSR and TPI Parts
Car: 73 Camaro LT/RS
Engine: 327
Transmission: Supert T-10
HSR and TPI Parts
This is what is left from my 327/T10 part out. I am installing an LS6 and have no need for my Small Block Parts anymore. I am selling the Fuel Injection setup in pieces. If someone is interested in matching up the harness and computer with an intake, injectors, a distributor and MAF, let me know and I may be willing to do a package deal.
Polished Holley Stealth Ram with Fuel Rails, TPI Throttle Body with removed crossover passage and Lokar Throttle Cable Bracket for standard SBC heads. Part Number 701R-126. This was cast on 12/03/01. Ports appear to be 1.75" by 1.90" SOLD
Engine: 327
Re: HSR and TPI Parts
Factory TPI MAF Computer EFI controller with Moates G1 Memory Adapter with rewritable chip. Harness was stripped of unnecessary wires. Computer is a 1227165 ECU running 6E APYPWB code with Wideband Data Logging (https://www.thirdgen.org/forums/diy-...e-linear.html). Harness will come with MAF relays, EST box and Heated Narrowband O2 sensor. You will need to supply your own Wideband O2 input signal from a Wideband gauge. All cut wires are clearly marked and labled. Harness is covered in Jegs Flexbraid on most of the engine sections and a corrugated tubing over the rest. Sold
Factory TPI manifold with fuel rail. Manifold is a MAF manifold with the 9th injector. The 9th injector hole has been blocked with a plug and the fuel rail was modified with -8 feed and return fittings in the rear. Has aluminum distributor cover, Thermostat housing and all correct bolts are included. $150 + shipping
Engine: 327
Factory TPI 350 22lb injectors part number 17087325 Sold
36lb Injectors. Part Number 0280156811 These were cleaned and tested by South Bay Fuel Injectors on 08/16/13 and worked perfect. Sold
.jpg)
Factory MAF, Spectre intake tubing and 9 inch AEM Dryflow filter $75 + shipping
.jpg)
Engine: 327
Large Cap GM TPI distributor with GM HEI Coil and Cap. Sold
Small Cap GM distributor with GM module and MSD Rotor. $30 + shipping
MSD Blaster Coil 8226 for TPI/TBI engines with custom aluminum mount to mount coil to the back of the head. $30 + shipping
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Im interested in the coil and rails
Sorry, the ones off of the stealth ram if you're willing to part with them
Engine: 327
Ok, how much for the coil shipped to 84081?
Engine: 327
Engine: 327
Engine: 327
Engine: 327
Holley Stealth Ram, Factory TPI manifold, Factory MAF package, and Small Cap GM distributor still for sale. MSD coil is pending.
Engine: 327
HSR sold. I have the following still available
-Factory TPI manifold with fuel rail
-Factory MAF, Spectre intake tubing and 9 inch AEM Dryflow filter
-Small Cap GM distributor with GM module, MSD Cap and Rotor, and MSD Streetfire Wires
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
How much for wires cap n rotor? They come with sleeves? And how good is that intake?
Engine: 327
Ill take them how many miles on them? What kinda price for both intake and wires cap n all?
Engine: 327
The wires have low mileage on them. The engine and car had only 1000 miles on it since the restoration and I switched the wires to these to fit under the headers. This is actually a combination of two sets so they would all run under the headers.
Ok well send me your paypal ill take wires cap n sleeves
Car: 1985 camaro iroc z-28
Engine: 5.7L
dang , calling 2nd if not taken
Small Cap GM distributor with GM module, MSD Cap and Rotor, and MSD Streetfire Wires for under header routing with heat boots. $75 + shipping
Engine: 327
I don't have wires, cap and boots. Still have distributor with module and rotor. How about $30 plus shipping?
Sanjay
Aug 12, 2015 03:41 PM
