Steering box options and questions
Car: '89 Formula
Engine: 305 TBI
I'm not sure if this belong in the aftermarket product review section but I figure as this got no input in the Suspension section I'd try here. I know this question comes up everyone once in a while, but I have never seen any definitive answers (if there are even any):
So in this months issue of Popular Hot Rodding, they ran a special section on steering improvements. After the section on rack and pinion units, they covered steering boxes, stating that with new upgraded units you can get 90% of the improvement of a rack and pinion unit by incorporating a rack and pinion type spool gear. Not sure what that is. They listed several companies that sell new or rebuilt units, and I was wondering what you guys thought were the best options, especially if anyone has tried these units. In particular, does a rebuilt fast ratio box from a third gen compare well with a new unit? I believe mine is worn out and I plan on replacing it soonish. Here are the options PHR recommends and i put in others I know of:
http://www.detroitspeed.com/productp..._gear_prod.htm
$500, new, they say near rack and pinion performance. No one else says that, and DSE is an excellent company.
http://www.powersteering.com/
$225 for a rebuild on a 12.5:1 unit. I guess this the best performance you can get out of our boxes?
http://www.classicindustries.com/con...rchCatalogId=3
$550, why is this one so expensive? Thoughts?
And the two I know of:
http://www.flamingriver.com/index.cf...rod/prd330.htm
$600, like DSE a rack and pinion comparable device
And I know ARG makes a box but I cannot find a link for the correct application.
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Re: Steering box options and questions
Here's the AGR box, its a 12:1 box for $350:
http://www.summitracing.com/parts/AGR-225153/
Anyone on this forum got any input on steering parts?
Car: 87' IROC
16:1 doesn't not sound like fun on the street.
I just had my box rebuilt by Lee. I'll let you know how it is in a few weeks.
Car: 87 T-Top GTA
You could get a 16:1 out of a Astro van, used from the wreckers for $40. I'm leaning towards the AGR box myself!
The problem with 16:1 is that it would take alot more turns of the steering wheels to make the front wheels turn the same amount. It's slower, making city driving more tedious (actual effort will be less, but less of a direct feel) and corner carving would be scary.
backtothe80s
09-05-2015 12:39 AM
