Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Better than stock Cam
Old 01-15-2011, 10:36 PM
Napaman08's Avatar
I am basically looking for a cam that is a slightly better than OEM. Not well versed by any means. This is the first motor I have done and have recently had the block baked and new cam bearings installed, as well as both heads machined. I have found one at a local performance shop for 300 but hoping to find something slightly cheaper. Lastly the application is a 90 camaro 305 TBI with hyd lifters auto trans. Thanks in advance
Old 01-15-2011, 11:05 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Re: Better than stock Cam
did you read about the lt1 cam?
https://www.thirdgen.org/forums/tbi/...-ultimate.html
Old 01-15-2011, 11:30 PM
Napaman08's Avatar
Perfect seems like it was written for me. Only concern is now finding an LT1 Cam and getting the wrong one. I saw JEGS was listed know of any more ? Anyone?
Old 01-18-2011, 11:39 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
since the LT1s (and the 3rd gen SBCs) are hydraulic roller cams, buying a used one is not a bad idea. Look around some 4th gen fbody or corvette sites, I grabbed one for under $50 shipped in good shape. ebay may have something floating around too, lots of the LT1 owners upgraded to something bigger and just want a couple bucks to get rid of their leftovers
Old 01-18-2011, 03:49 PM
Napaman08's Avatar
Thanks, Do you need to r chip it or anything else?
Old 01-20-2011, 07:19 PM
bduffey723's Avatar
Car: not a camaro anymore
i got one settin here in a box. u can find them on ebay anywhere. they helped alot in my ex's 305 she had. i paid like 30 bucks for mine. they are on the classified section on this site or ebay all day long. no chip or anything needed but u may need to push in or ground down the pin that sticks out farther than wats able to go in there.
Old 01-20-2011, 08:24 PM
Napaman08's Avatar
Thanks for the info. I have been told that you should use the lifters from the same motor since they were broke in together. I should be fine with just all new lifters correct? Also you say you have one in the box. Your not interested in selling it are you?
Thanks again
Old 01-21-2011, 10:27 AM
bduffey723's Avatar
Thanks again
i didnt change the lifters and havent had any problems.. new ones wouldnt hurt though. and ya ill sell it i wont ever use it. i paid $37 for it. ill do $40 shipped if u r in the states.
Old 01-23-2011, 04:40 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
LT1 cam is a great upgrade for a 305.
Might want to replace the springs, locks and retainers with GM ZZ4 ones while you're at it. Try GMpartsdirect.com.
ZZ4 springs - 12495494
Locks - 19171528
Retainers - 12495503
Great price.
You don't have to replace the springs but it's cheap insurance...and when you upgrade to a ZZ4 cam and TFS 305 heads, you don't have to do the springs!!
Street Lethal
04-30-2019 12:14 PM
Orr89RocZ
04-25-2016 08:28 AM
sweet_87_iroc
09-25-2015 10:01 PM
camaro71633
09-01-2015 10:24 AM
Quick Reply: Better than stock Cam
