Aftermarket Vendor Review Provide questions and comments about aftermarket part vendors for the Third Gen F-Body.
www.kmjent.com/ procomp dist.
Old 04-06-2010, 04:14 PM
MADMAXGTA's Avatar
Car: 89 TTA
www.kmjent.com/ is a distributer of procomp parts,after recieving a EFI distributor from them It was faulty leaking oil up and out the shaft resulting in oil under the cap of the dist.
After speaking with 'jon' from KMJ he refused to accept my return stating this
"If I refund your money for this I will have to explain to my wife why I have no job"
very weak excuse for a very weak product.
I have heard nightmares about procomp parts and will never buy anything made by procomp again and will never order from KMJ performance, no matter what they sell.
Very bad buissness practice with very bad parts.
Old 04-11-2010, 11:49 PM
87tpiz28's Avatar
Car: 1987 z28
Engine: 305tpi
Axle/Gears: 2.73 posi
Re: www.kmjent.com/ procomp dist.
Woah! i thought i only had bad luck with them. I ordered a distrib, no oil leaks here but the car ran like crap. massive backfires, crazy idle, but the stock one ran beautifully after i removed this procomp junk. i emailed them and they got me a replacement ignition module (free and i though great service!) so before i get the module i ordered a mini starter because they took care of me good. So i get a new module, new mini starter, get them installed and the car still ran crappy, installed the original distrib and back to smoothness.
then after a weeks worth of use the starter gave out. i paid around $80 for this starter, and after emailing a rep i would get a refund for the price with out shipping, so there i was out $10 plus the $15 to ship it back. and if i wanted a replacement i would need to send them another $15 so they could ship a new one. so because their starter failed i would be out $40 extra.
I didnt send anything back because i figured it would not be worth giving KMJ money for a product that fail and one that never worked. no more KMJ for me
Old 04-20-2010, 07:47 AM
Zaher's Avatar
I live near where these guys are based (Ames, IA) and they are a complete scam. I have heard nothing but horror stories from people locally about their business practices. Their cylinder heads have poorly finished castings and their SBC intake manifolds leak. Their customer service is terrible. They also have an "F" rating from the BBB. In all cases the BBB investigated, KMJ Performance simply ignored them.
Stay away from these guys. If the price is too good to be true, it probably is.
Old 04-20-2010, 08:34 AM
Twin_Turbo's Avatar
have one lying around from the PO who installed it, the shaft size is really small, engine stumbled and idled erratically hot...stock one runs smooth as silk, a true piece of crap
Old 04-20-2010, 05:35 PM
one92rs's Avatar
Car: SOLD!!!!!
wow i have one. i do have a stumble and odd idling. wish i could afford a gm hei or even a summit one. i will replace it one day.
Old 04-20-2010, 05:41 PM
Twin_Turbo's Avatar
summit brand is the same chinese junk, either oem or MSD would be my choice
Old 05-01-2010, 07:11 PM
one92rs's Avatar
Car: SOLD!!!!!
just put a msd hei in the car. took out and chunked the procomp hei. heck is was even leaking oil in inside the distributor. now it runs so much smoother and will idle perfect at 650 rpm's.
Old 05-02-2010, 06:34 PM
one92rs's Avatar
Car: SOLD!!!!!
especially after a 210 mile jaunt today. the msd ran so perfect i think i will tell all to not even touch pro comp anything.
Old 05-07-2010, 02:00 AM
MADMAXGTA's Avatar
Car: 89 TTA
Anyone notice a power loss with the procomp dizzy?
Old 05-07-2010, 04:20 PM
Bowtiebruiser's Avatar
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
I bought a procomp mechanical fuel pump pushrod from KMJ and it was worthless, it clattered and made a ton of noise not to mention a 2psi drop in pressure. I never bothered with contacting KMJ after hearing about their poor CS
Old 05-19-2010, 06:20 AM
jag327's Avatar
Car: 82 Camaro
Engine: 327/30 over 1965 block
Transmission: 4 speed M22 trany
Axle/Gears: 373
I would call procomp and talk to Baldur Castro about parts breaking or going bad.
I had 3 items go bad 1 rocker shaft crack but only when I rev pass 7200 rpm
this could have broken because I did not have a stud girdle.
But they replace the rocker, still using them only now with a stud girdle for about 6 months now.
I broken a, MSD, Mallory, distributors before cost a lot to repair.
1 thing I learn try to have your motor built up so all your parts are in warranty because if you install new part out of warranty man it cost a lot to repair.
I broken procomp dristrubutor out of warranty they sent me 1 free any way.
I only pair $46.00 for it. This was last year and bought 2 more for other motors I have works find so far.
The 1 motor make's 526 hp small block chevy.
Old 11-12-2011, 09:42 AM
yardman's Avatar
kmj is a rip off. trust me i'm not going to say what happen to me it will take to long. just stay clear from them dont give them your hard earned money for there junk and lies
apo_bailon15
03-28-2016 05:20 AM
pjsparts
09-17-2015 01:28 PM
db057
08-22-2015 08:17 PM
Rallyssport
Aftermarket Product Review
06-08-2001 12:56 AM
MrMike99
02-28-2001 05:47 PM
Quick Reply: www.kmjent.com/ procomp dist.
