Crankshaft to transmission pivot bearing thing
Old May 9, 2024 | 01:30 PM
killerbean's Avatar
Car: 88 GTA
Engine: 5.7 TPI
Quick question. I am about to bolt the transmission (700r4) back up to the motor and I was wondering if the bearing thing in the crank is supposed to turn freely or not? It seems like it's rusted tight. Any help is much appreciated.
Old May 9, 2024 | 01:37 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Crankshaft to transmission pivot bearing thing
Is that in the back of the crankshaft? Old pilot bearing for manual?
Old May 9, 2024 | 01:39 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
not needed with an automatic-leave as is . with a stick tranny,must be replaced with a good one.Pilot bearing.
Old May 9, 2024 | 01:40 PM
killerbean's Avatar
Car: 88 GTA
Engine: 5.7 TPI
Yea it's in the back of the crank. Do automatics have pilot bearing? The car the motor came out of was setup for an automatic. It didn't have a clutch or anything.
Old May 9, 2024 | 01:43 PM
killerbean's Avatar
Car: 88 GTA
Engine: 5.7 TPI
Ok, not sure why the motor has a pilot bearing then because the car it came out of was setup for an auto. Appreciate the response.
Old May 9, 2024 | 02:16 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Has the motor ever been rebuilt?
Maybe someone threw in a 305 crank for manual trans, it happens.
or maybe was going to do a manual swap and changed mind?
Think thirds used a bushing not a bearing so its not factory.
Whatever the reason, id remove it.
Old May 9, 2024 | 04:35 PM
capted60's Avatar
Make sure the converter slides freely into the crank. You may have to remove that bearing if it doesn't.
Old May 9, 2024 | 04:47 PM
killerbean's Avatar
Car: 88 GTA
Engine: 5.7 TPI
It ended up fitting without taking it out.
Old May 9, 2024 | 04:48 PM
That bearing won't bother the converter. It doesn't go into that hole in the crank. It's not bothering anything as long as the car has an automatic.
Personally I'd just leave it. Sure, the car will go faster without it (it's what, an ounce of dead weight, or whatever), but looking at that mess in there with all that rust, it'd be far more trouble than it's worth to try to remove it.
Old May 9, 2024 | 04:51 PM
killerbean's Avatar
Car: 88 GTA
Engine: 5.7 TPI
Haha yea I didn't really wanna deal with that so I was happy it fit.
85Iroc-Z
Dec 10, 2011 01:43 AM
hansw3
Jun 30, 2010 02:57 PM
heavy_chevy29
Apr 2, 2005 06:59 PM
joes88gta
Jan 5, 2002 09:02 PM
