Chopped HSR to fit under a C4 Vette hood
Car: 85-Vette
Engine: 406ci
Transmission: TKO-600
Axle/Gears: 3:45
I know this is not a Vette forum but I thought people might want to see the insdes of a HSR Plenum
Engine Specs
406-CI
Bullet Billet Custom Grind HR cam 233/233, 284/289, .576 lift w/1.6rr's
11:1 CR
68 CC, AFR 210 heads, 300 CFM @ .600 lift
Wiseco forged Pistons, Eagle Forged Rods, Cast Crank.
Centerforce 400 Crank Flywheel / Centerforce DF II Clutch
Flow Kooler Water pump w/ Dewitts Radiator
ZF 6 speed , Hurst Billet Shifter
3.45 rear gear
Hooker 2151 cut and rewelded to clear plugs
BBK 58 mm TB
FMS 24 # injectors
MSD 8366 Small Cap, MSD 6AL, MSD 8.5mm wires
Accell Shorty Plugs
86-89,,, 165/ECM
Cut Apart to an Overall Height of 2.900 inches
Welded back together
Engine Specs
406-CI
11:1 CR
3.45 rear gear
BBK 58 mm TB
FMS 24 # injectors
Accell Shorty Plugs
86-89,,, 165/ECM
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
Originally Posted by Demon355
That looks so much nicer than a stock HSR. I want to see some numbers...
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
It looks like a taller LT1 or mini ram kinda...I like it though. I didn't know the HSR had the bolt holes like that. Seems odd to me.
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
that thing is truely a work of art, joby did something similar to his but i believe he machined the holes in the bottom on the plenum bigger to fit over top the base.
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
Thanks for the kind words,
I love being able to remove the plenum when I want!
With how many corvette owners there are trying to make HSR's work, you'd think holley would just fix the stupid too-tall design.
Nice work. Came out really good.
-- Joe
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Been seeing a lot of posts from corvette owners on here lately. Glad to see i'm not the only one that thinks corvetteforum is filled with retards.
Good work on the intake. Looks sick. Engine bay does in general.
-- Joe
-- Joe
Car: 89 Formula
Engine: 5.7 TPI
did you ever get any numbers on this thing? id kinda like to know what it would do vs. a stock one on the dyno. how long did it take you? i might even get with you to do one for me if you want.
Car: 1969 Nova
Engine: LT4 Hot Cam L98
Axle/Gears: 3.42 8.5" 10 bolt
That is the cleanest HSR I have ever seen. Kool. Are there any Dyno # to see if chopping the intake did anything?
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I love it, although I am more than curious to see if this affects flow or dyno numbers at all.
I thought of something though, those bolt holes seem like they are blocking some flow. Might it be worth it to cut out those holes, block them off, and weld the bottom of the plenum to the top of the plenum? Would this make it impossible to reach the bottom intake bolts? Just an idea.
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
Yeah, I am sure the bolt bosses block some flow, my AFR 210's are ported so they flow 296 @ .600 lift,,,but I really wanted the plenum to be removable,
Regarding the performance this is the result;
Miniram 1/4 mile @ 115 mph
Superram 1/4 mile @ 115 mph
HSR 1/4 mile @ 115 mph
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
[QUOTE=LD85;3103193]yes I have and my empty wallet is proof
WOW! You're worse than I am!!!
I've currently got the SuperRam and am considering going to the LT1 (essentially a MiniRam as I understand it) conversion just for clearance on my strut tower brace and ease of access to injectors, valve covers, etc. plus the ease of installing and removing occasionally. Plus I've got a MiniRam for an LT1 sitting in the garage as well... (plus an Lt1 block fresh from the machine shop .020 over and various parts for it - still looking for a good stroker crank and pistons though, wallet is too light at the moment <sigh>)
Wow! What made you try all 3 setups? Different cars? Or did you have one intake for a while, sell it and then get a new one? It's interesting that all 3 yeilded you the same times at the track, considering the fact that the mini ram and superram are considerably more expensive than the HSR.
Nice work man.
Nice work man.
Down to a total height of 2.9" from what originally? Its a shame the guys at Holley dont listen to people when they call tech and tell them that stuff doesnt fit certain applications.(like I do.) What you did is exactly what I was working on for my 92 TA because it was either HSR or Carb. Shame i have to modify something that was already "engineered".
Totally.
You know, is it really necessary for the plenum to be that tall? I mean, I can only imagine that by chopping it, youd lose some performance, because if the guys at Holley were smart, they would have made it smaller to begin with to reap the profit for all the C4 owners, as well as 3rd gen owners.
If there IS no difference in performance, Holley should just manufacture that 2.9" version. This is why I am so intrigued to see dyno numbers, so to compare it to a similar setup to see if there are any staggering differences. (seems not though, as his 1/4 time was on par with the miniram and the superram).
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
Down to 2.900 from 4.0"
1 Post
Car: projects.......
Although this is a couple months old, I too would likt to say nice work. It looks better than the original. Looks to me like it should still have plenty volume of air to handle most any engine that would be using a street minded intake.
Great Job!
Great Job!
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
Thanks guys, I love the intake and it breathes well on my 406ci.
Once I get my clutch to stop slipping, I will have some dyno and track data.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Awesome work...
Having been thru all 3 of those intakes on your 406. Could you share your thoughts on each one? How the motor responded to each? In terms of overall power?
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
The Superram was a PITA to install and when I went to take it back apart, there were 5-6 bolts that were loose that needed re tightened but without removing my valve covers and a couple of roller rockers, I would never have been ale to get to get to the again, waaay to much of a PITA for me. Also, the plenum rubbed my wiper motor cover so there was more clearancing, and the stock HEI distributor was less than 1/8" from the plenum. In terms of performance, my AFR 210's were too big for the Superram and the low RPM TQ was impressive but it choked at @ 5200 RPM, the car would just die in terms of performance which necessitated short shifting at @ 5200-5400rpm. My top MPH was 115.2 MPH using new 3.45 rear gears and a ZF 6 speed,,, and shift light at 5500rpm
With the Holley Stealth Ram, I had to change to a smaller distributor, bring the fuel lines in from the rear instead of the stock/front location and obviously trim the plenum height and thermo housing height. But in terms of performance the HSR is a nice compromise between the MR and SR, runner length is little longer so low end TQ is still strong and it breathes up to 6000rpm,, the top speed was 116 using the 3.45 and ZF 6 speed,, and shift light at 5800rpm
My 60' times have never been better than 2.10 due to tire spin and a slipping clutch. A new street twin this spring should fix the clutch issue and I will have to work harder on my 60' since I use street tires, it will only get marginally better,
My.02 = use the HSR unless you dont mind shifting at 5400rpm.
mainly it is a mixed bag over there, you have the knowitalls, the wananbees, the waxers and the wingdings.
But with that said, there are a lot of decent guys there!
I am member #349 and have been there since Feb-1999 and have seen a lot of weirdness in the past years
The problem with the Super Ram is the TPI style intake manifold. The Edelbrock manifold and clones are better than the stock manifold.
The problem is the pinch point just inboard from where the manifold meets the head. The best JerryWho was able to get was 1.9 square inches with a lot of grinding on his Edelbrock. This is still smaller than the aftermarket performance heads and becomes the choke point.
Not good to have the choke point in the intake manifold and power suffers. The choke point should be at the intake valve. Everything upstream should be larger. This is why you can't get peak power much above 5200rpm with the Edelbrock TPI intake. Will have to see what Jerry's manifold does with his being opened up. Welding additional material would be a solution so that the area could be opened up more.
Now there is the First Injection TPI style intake manifold which does address the problem. You can hog it out to say 2.7 square inches if not more. That will get the job done. If need be for a larger motor you can always weld more material.
One other thing the First intake manifold does is it has a radius transition from the intake manifold to the head. The others are virtually flat on the floor and therefore creates an angle where the manifold meets the head. Not the best transition.
Stay tuned as I'm going the First Intake TPI manifold route. Maybe the best of both worlds. I can also adjust the runner length for the best harmonics.
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
Depends on your cam and RPM limits.
Superram is good if 5500rpm is your max.
Miniram is good if you want peak HP above 4500/4800 RPM and if you rev past 6000RPM, and if you have a dual pattern cam and have 3:73/up rear gear.
Stealth is all around good up to 6000rpm.
My guess is that an LT1 intake would do fine and be more streetable.
Car: Silver 1980 Corvette (L82 w/TPI)
Engine: L82
Transmission: TH350
#44
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
Axle/Gears: 10bolt 3.42/posi
great write up and you did a great job on the fabrication. I love my HSR, very responsive and easy to work with.
#46
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
Re: Chopped HSR to fit under a C4 Vette hood
Well, I made the mistake some time @ 2003,,,,of asking about putting Coilovers on my 85,,, 75% said it was just Bling Bling....
Now there are a lot of people with Coilovers and saying, they are pretty goo.
BTW, I will be putting coilovers on a week from Saturday, ordered the parts today!
#47
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
mANN tHAT sURE dOES lOOK hELLA sWEET! I cANT dECIDE oN wHETER tO pUT mY tPI iNTAKE sETUP oR mY lT1 oN mY rAM jET 350....aNY sUGGESTIONS? iTS A lIL cRATE mOTOR i BOUGHT fROM a fREND. I oRIGINALLY hAD A 305 H.O....nOT eNOUGH pOWER tHOUGH! sO mAYBE u gUYS cAN gIVE mE A hEADS uP!?
#48
Car: 1987 Trans Am
89formula350b2l (06-10-2020)
#50
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
LD85,
Thats great work on that intake and that whole engine bay looks real clean. It seems like its a great balance of the three manifolds.
In terms of chip tuning, did you run into any troubles with those manifolds especially the miniram??
Rabi C.
Rabi C.
