Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR & 58mm TB
Old 10-30-2014, 08:20 AM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
HSR & 58mm TB
Currently running stock TB on my 414. Wondering if a 58mm TB will help with flow distribution. Looks like the front cylinders would starve for air in high flow conditions. 58mm TB may reduce velocity.
Also using the stock intake duct and wondering if it is a restriction. Thoughts?
Old 10-30-2014, 12:11 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: HSR & 58mm TB
I would say yes to all. 58 will help it breathe but slow air down enough at part throttle it may improve distribution. I still saw issues on my 383 with a 58 but most all intakes with front fed plenum will have some distribution at idle and part throttle.
Stock intake ducting would be abit of a restriction on big cubes. My 383 didnt seem to pick up anything from stock ram air tpi snorkel and stock gutted maf when i made 3.5" cold air piping and 3.5 maf but thats 390-400 whp range. A good 414 would be atleast that but make more trq and trq is airflow
Linson
09-25-2021 07:55 PM
86z89iroc
10-05-2015 01:04 PM
mike22115
09-28-2015 04:49 AM
IROCNParts
09-24-2015 10:50 AM
BBSDesigns
09-22-2015 03:08 PM
Quick Reply: HSR & 58mm TB
