attatching door molding
Old 02-11-2012, 12:58 PM
IROZINCO's Avatar
So - when i got my car painted, they took off all the door molding and threw it away. I've got some more, but now worrying about how to attatch it. I would presume that its supposed to go at the farthest out point on the door? The apex of the curve as it were? Its got old 'glue' on it, i'll have to take off, wondering what to use to RE-attatch it that won't damage the paint. Also, its white, so it'll have to be painted. I'm thinking doing body color (blue) but i think they were originally black. The car is blue with gold trip. The mirrors are body color, the door handles are black. What do you think? And do i need to primer them before i paint them?
Old 02-11-2012, 01:45 PM
TheEndofanEra's Avatar
Car: 92 Camaro RS, 93 Caprice Classic
Engine: 3.1L V6, 5.0L V8 + 700r4 on both
Transmission: Rebuilt 700r4 in the Camaro
Axle/Gears: Stock with 3.23s ...3.73 later?
Re: attatching door molding
If you mean that that go right along the bodyline, then yes. You'll want to use some 3M automotive double sided tape, I believe it was, to attach them after you've scraped off the old tape from the mouldings. And you'll want to scuff with red scotchbrite pad before you primer and paint them.
If they're the rounded type of mouldings (90-92) then I'd paint them body color, if they're the thinner square style (82-89) then I'd paint those black like they would've originally been.
Old 02-13-2012, 05:03 PM
IROZINCO's Avatar
well, i have the pointy ones, so i agree on the body color. Next question. HOW the (#@*&$(!!!! do i get the OLD adhesive off?!?!? I've had it soaking (literally!) in glue remover for 24 hours, and its still stuck on like.... well, you know! I tried a scraper, and a knife, its just stuck firmly on!
Old 02-13-2012, 05:08 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
http://solutions.3m.com/wps/portal/3...beRJ5GMFSMV0gl
Old 02-13-2012, 06:47 PM
That'd work, or you could try warming it with a hair dryer or a heat gun set to a fairly low temp and scrape it off with a bondo spreader or just try and roll it off. That tape is astonishingly tough.
Old 02-13-2012, 06:57 PM
COTM Editor
BADNBLK's Avatar
Leave em off! Walk the extra 100 feet into Walmart to avoid the door dingers up front... if your like me, you could use the walk
Old 02-15-2012, 04:01 AM
IROZINCO's Avatar
well, i think all of us could use more exercise, but as this is my trip car, and will get parked in hotel parking lots, restertaunt parking lots, gas stations, etc, i really wanna get the door protection on! I'll have to see about trying the hair dryer, or maybe a blowtorch!
Old 02-20-2012, 04:55 AM
hilltop530's Avatar
Car: 1987 Iroc Z28 Camaro
Engine: 5.7 TPI
This sounds a bit odd but, If you have a dremel place a rounded eraser head on it. Just like the ones on the ends of pencils. I used a larger one that was rounded. It took all the garbage off without cutting into the paint. This also works well for pinstripe removal.
The below image is one you would want to use.
Attached Thumbnails attatching door molding-145914656_round_shape_tpr_student_eraser_240.jpg
92-Formula
12-12-2015 10:34 PM
1992Z28!
11-19-2015 07:33 AM
tglennon11
09-23-2015 05:30 PM
Quick Reply: attatching door molding
