must slam driver door or won't shut all the way
Old 01-22-2011, 07:55 PM
Phx89Iroc's Avatar
Car: 1989 IrocZ Convertable
Engine: 350 5.7
Transmission: AUTO 4 SPD, THM 700 R4
Axle/Gears: AXLE REAR, 2.73 RATIO
this is the second 3rd gen i have owned and both have the same problem. Last car it was both doors, this time its only the driver door. If i dont slam the door hard it won't shut all the way. I am thinking something is worn down and needs to be replaced or adjusted? I dont like the slam it, i keep thinking i will end up knocking the window or power off alignment or something. Anyone know how to fix this with adjustment or new parts? thanks.
Old 01-22-2011, 08:13 PM
IMissMy86TA's Avatar
Car: 1988 GTA 5-spd TPI
Engine: 5.0 TPI
Transmission: T-5 baby
Axle/Gears: 3.45
Re: must slam driver door or won't shut all the way
Open the.window a crack then shut it normal...
Old 01-22-2011, 08:19 PM
Phx89Iroc's Avatar
Engine: 350 5.7
my iroc is convert, and the windows are usually down. it happens regardless.
Old 01-22-2011, 08:22 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
This is a very common problem with these cars and the heavy doors. A company named "Top down solutions" offers a few different ways to fix the problem.One being a "door hinge repair kit " and the other a "EZ door alignment tool" Here's a link to there site. I beleave you ask for Lon.
http://www.top-downsolutions.com/ind...071d86c5ab076b
You may also want to get a door spring tool to help with the install.
I have used both the door hinge repair kit with the spring tool and it worked just fine, though its still a little hard to close because of the new weather striping.
Old 01-22-2011, 10:21 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
You should not have to put the window down to close the door. That vent in the jamb is to help release some pressure.
Open the door a little so it is still lined up with the car and not wide open like a bird ready to fly.
Lift up and down on the door. All doors will flex some when you arm strong them but ones with bad pins and bushings will feel like there is a loose spot in them.
Old 01-22-2011, 10:45 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
What Ronus said, these cars have a habit of sagging doors, heavy *** doors will do that over time.
Old 01-23-2011, 11:56 AM
Krase's Avatar
Car: 84 Camaro Z/28
Transmission: 5 Spd
Axle/Gears: 4.10
i was asking myself this same thing, very helpfull. thanks guys.
Old 01-23-2011, 09:05 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Make sure to replace upper bushings and lower pins and roller bushings. Check if your hinges are still good. If they are, then just get bushings and pins and your door will close like new (once adusted correctly)
Old 01-25-2011, 06:36 PM
Engine: TBI,5.0
If you don't want to buy the repair kit right away then I wound go to a body shop and ask them to lift/align the door (they should have the tool) It only takes a minute to do,and the shop I went to did not charge me .It lasted until I installed the hinge repair kit from Top down solutions.(again I recommend the spring tool).
Old 01-25-2011, 07:36 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Sounds like to me you need to rebuild your hinges that would need pins bushings and I would also replace the detent or you could buy new ones
Old 01-25-2011, 08:40 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Hinges need new bushings. You can get new ones at Napa.
Old 01-26-2011, 09:05 AM
Top Down Solutions sells everything you need, literally. Tools, bushings, pins, hinges, springs, etc.
Old 01-27-2011, 08:15 PM
Phx89Iroc's Avatar
Engine: 350 5.7
cool thanks, ill try a body shop for a short term solution just so i don't have to keep slamming the door, then look at getting the new parts. I just hate doing that every time i get into my car
Old 01-27-2011, 08:34 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
If you do need pins and bushings, which I bet you do, keep an eye open in the "Group Buy" section. There is a thread and people are requestion another buy for the kits by AndysZ28. Don't know if there will be another or what the GP price would be (its been asked a few times but the guy never answers on how much) but it may be worth keeping an eye on.
Old 01-29-2011, 05:20 PM
Phx89Iroc's Avatar
Engine: 350 5.7
i found a body shop by my house that said they would put in whole new module on the doors driver/passenger (i don't know what it's called) where it latches, and also new upper/lower hinges where the swings open/closed on the driver side but the passenger ones were ok. New from the dealer installed for 150$ so it seemed like a fair price. Getting it done monday.
Old 01-29-2011, 05:22 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Parts and labor? They do have to remove the door, drill out the spot weld and bolt a replacement hinge on.
If thats the price for all that then go for it!
1992 Trans Am
05-10-2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
Out-Cast
08-23-2015 06:33 AM
BlackTopKing
08-19-2015 12:13 PM
chevyguy1999
08-16-2015 08:49 PM
Quick Reply: must slam driver door or won't shut all the way
