Removing Paint?
Old 01-24-2011, 05:15 AM
Guest
Guest
Posts: n/a
Removing Paint?
How would i remove paint from our interior body part plastics.
I need to get it off without scratching it or anything like that.
Old 01-24-2011, 04:17 PM
Guest
Guest
Posts: n/a
Re: Removing Paint?
Bump?
Old 01-24-2011, 04:52 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: Removing Paint?
Try rubbing alchohol first. You gotta be careful with plastic. Some paint solvents are plastic solvents. Wet a paper towel with the alchohol and rub the item easy just to see if the paint will start to dissolve. You may have to let it sit a little. Of course, this stuff evaporates pretty quick. Just take it slow to make sure it won't damage the underlying plastic. This is a slow way of doing it but reduces the risk. I'm sure some of the folks on here have a better way.
Steve
Old 01-24-2011, 05:18 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Removing Paint?
Alcohol can soften some plastics. Try it in a test area that wont be seen first.
You might want to try an automotive paint store and ask them. There is a wax and grease remover for plastic (SEM makes one for instance) that may work. You also might want to get to it quick if the paint is still fairly fresh.
Old 01-24-2011, 05:40 PM
Guest
Guest
Posts: n/a
Re: Removing Paint?
I tried paint thinner i can't get the rest of the overspray off i thought i masked it good.
Old 02-10-2011, 02:58 PM
ChromePhoenix's Avatar
Car: 85 Trans am
Engine: 350 carbed
Axle/Gears: 9 bolt rear disk
Re: Removing Paint?
This may sound a bit backwards. but if nothing else works just paint over the paint with some interior vinyl dye/plastikote or something?
Old 02-11-2011, 05:46 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Re: Removing Paint?
You could use some 1200 grit wet and dry sandpaper. Cheap at Harbor freight.
Just use lots of water and lots of sandpaper but don't push very hard. It will knock off most the the overspray and feather the rest for the repaint without hurting the grain of the plastic.
Old 02-11-2011, 06:55 PM
rich5's Avatar
Car: 91 camaro RS
Re: Removing Paint?
sandpaper will take away texture. paint thinner on towel
Old 02-11-2011, 08:22 PM
Car: 1989 IROC
Engine: 305TPI
Re: Removing Paint?
I see. So it's overspray from painting the car that your trying to remove.
I thought you were removing vinyl paint to change interior colors or something.
Good luck with that
Old 02-11-2011, 09:14 PM
rich5's Avatar
Car: 91 camaro RS
Re: Removing Paint?
ohh overspray, i used commit and a brillow pad
Frozer!!!
01-19-2024 04:55 PM
Vintageracer
01-10-2020 05:33 PM
NBrehm
08-25-2015 11:49 PM
Wife'sCar
08-22-2015 01:46 PM
3rdgenparts
08-08-2015 07:09 PM
Quick Reply: Removing Paint?
