What is the proper way to setup a vacuum canister?
Old 09-16-2007, 07:16 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
I got an aluminum one from summit racing...I hooked it up...breaks are still stiff as all hell.
Old 09-17-2007, 08:25 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Re: What is the proper way to setup a vacuum canister?
Old 09-18-2007, 12:30 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
On my factory setup it was like this. Manifold vaccun port to the filter, filter to the t-off and t-off to the Booster/ck valve. On my vacc canister it was Manifold vaccum port to the filter, filter to the t-off, t-off to the Canister/ck valve, Canister out to the Booster/ck valve. I didnt have any issues
Old 09-20-2007, 09:45 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
i got carb to the can, can to break booster and stiff...no filter...what should i do?
Old 09-21-2007, 12:38 AM
Mikz86TA's Avatar
RU still running the vaccum ball, the check valves?
86Firebird86
12-26-2015 07:21 AM
Bubbajones_ya
09-14-2015 08:38 PM
webeeZ28
09-14-2015 12:00 PM
snakeshooter
09-07-2015 11:13 AM
TheExaminer
09-06-2015 11:40 PM
Quick Reply: What is the proper way to setup a vacuum canister?
