15x8" weld pro stars on '92 1le rear
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
i swapped a 1992 1le differential into my 1986 sport coupe. my original wheels will obviously not fit over the 1992 1le aluminum calipers. i have a set of 15 x 8" Weld pro star rims that need to go on this rear. question is if they won't clear, how much grinding will i have to do on the calipers to attain adequate clearance? will the grinding of the cooling/ support fins affect performance or reliability in any way? i know there are new weld pro stars with more clearance, but i already have the original ones. i would prefer to keep these rims if i can due to financial reasons.
any suggestions or opinions would be greatly appreciated!
thank you!
thank you!
Car: 86 coupe
Engine: 383
Re: 15x8" weld pro stars on '92 1le rear
I hate asking questions during racing season, but i really need some input here.
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
I was able to bolt up a set of Z28/RS 15" 5 spoke wheels to my 92 rear with PBRs with no clearance issues at all.
ambainb
04-25-2016 09:21 PM
LT1Formula
08-20-2015 09:36 PM
