what is this brake piece (front caliper)
Old 03-17-2012, 09:03 PM
Steven6282's Avatar
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
Trying to put my brakes back together and had a piece come out while trying to brake some bolts lose on the suspension. Can anyone tell me what this is and possibly a picture of how it goes in?
Old 03-17-2012, 09:44 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: what is this brake piece (front caliper)
Anti-rattle clip for the brake pad. The big V on the upper right goes into the caliper piston.
The left side lower tab looks like it goes into a hole in the brake pad backing plate. Been a while...
The left side upper hook goes over the pad backing plate.
Basically, the left side stuff holds onto the pad backing plate, with the upper right V going into the hollow of the caliper piston.
RBob.
Old 03-18-2012, 12:21 AM
Steven6282's Avatar
RBob.
Thanks, I'll be working on it again tomorrow but I think I know what you mean from looking at it earlier.
On another note... what actually holds the pads into the caliper? When I took mine off there wasn't anything holding them in place, seems like they would be leaning and rubbing the disk like that?
Old 03-18-2012, 08:24 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
They are full float per design, pinning just causes bind.
Old 03-18-2012, 08:28 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
That spring holds the pad on to the caliper slightly. The caliper, pins and knuckle are what actually locate the pads. No need to worry about the pad dragging on the rotor when brakes are released. If there's no hydraulic pressure, the spinning of the rotor will move the pad/piston in enough so that it won't drag.
Old 03-18-2012, 08:56 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The inner pad is held by the anti-rattle clip.
The outer pad gets the tabs on it crimped onto the caliper body. There is one long tab center on one edge of the pad, then two smaller tabs on the outer edges of the pad. Usually use a large pair of channel locks to bend the smaller tabs into better contact with the caliper body.
They are more for anti-rattle then to retain the pad in place.
RBob.
Old 03-18-2012, 01:03 PM
Steven6282's Avatar
Hmm, I'm not sure if I understand how this is supposed to work or if they were ever even installed right.
The outer pad does have some tabs on the top side that would prevent it from falling off, but I don't see how those tabs would prevent it from leaning in. The inner pad, the metal piece on the back of it that this anti rattle clip hooks to is actually lose on one side from the pad itself a little.
I mean I guess it works cause the brake pads are not that old (maybe 5k miles on them) and they don't have much wear on them and the rotors don't have any marks to indicate rubbing on them, it just doesn't make sense to me atm lol. Perhaps I'll figure it out when I put them back on later.
1992 Trans Am
05-10-2023 07:19 PM
1992rs/ss
05-19-2020 07:02 PM
Reddeath210
10-06-2015 08:20 AM
MustangEater82
Brakes
08-11-2015 07:52 AM
Ginamariegault
Brakes
08-10-2015 08:33 AM
Quick Reply: what is this brake piece (front caliper)
