E-Brake Equalizer adjuster thread
Old 07-05-2012, 12:34 AM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
On an '89 IROC (10 bolt w/ drum brakes), what is the thread on the emergency brake equalizer/adjuster? Is it 1/4-24, 1/4-20, or metric? I've done a search and come up empty.
I'm in the middle of swapping in a '95 posi disc brake rearend and can't get the nylock nut off the threaded rod for the equalizer/adjuster b/c it jams part of the way down. I'd like to run a die up the threaded rod to clean it up but want to be certain what the thread is.
Here's a pic of the threaded end I'm talking about:
Thanks!
Old 07-15-2012, 12:40 PM
nhgator's Avatar
Car: 1985 T/A
Re: E-Brake Equalizer adjuster thread
My 85 takes a 10 mill. wrench,looks to be a 6 or 8 mill. fine thread
Old 07-16-2012, 07:08 AM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Yep, it's an 8m x 1 thread. Thanks!
Btw, here's a pic of how we solved the equalizer issue. If the thread hadn't been messed up on the original cable, it might have been long enough as it was.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
J-money
01-04-2019 09:45 AM
Lanz06
09-14-2015 07:16 PM
SG91camaro
09-05-2015 10:27 PM
Buickstaged
Brakes
09-04-2015 07:53 AM
Quick Reply: E-Brake Equalizer adjuster thread
