1991 Z28 hardtop roller. LOTS of mods
Im just feeling the waters here. I may either sell or part out my 1991 z28 hardtop in order to start a new project. This car does NOT come with an engine or tranny. I will throw in the stock TPI setup that came off this car along with the stock serpentine setup as well. it also does come with a set of stock 16' 4th gen camaro wheels. It is a 1991 Z28 hardtop car. Little surface rust in different areas. Cars has current mods:
-SS hood with custom billet cowl area grill
-6 point CE roll bar with swing out. custom rear bars to use rear seats
-NEW Holley intank fuel pump.
-new GM fuel lines to and from tank
-4th gen disc LT1 rear with 3.73s. rear has under 500 miles since rebuild
-KYB shocks and struts
-Eibach prokit springs
ES bushings for swaybars
C5 Z06 front brakes( rotors and calipers with pads)
-UMI LCAs and adj, track bar. BRAND NEW no miles on them (red)
-LCA relocation brackets weld on rear
-Spohn T56 torque arm with crossmember and DS loop.(red)
-Spohn polished strut towers(brand new)
-Spohn red tie rod ajusters new in box still
-complete black deluxe interior minus gauge cluster. interior is in good shape
-complete exhaust setup(Hooker LTs, custom 3" S.S. ypipe w/3" Hooker catback.
-custom made T56 crossmember for use with custom Ypipe(not a cheapo)
-custom audio setup. all you need is a sub and headunit. I spent $1,000 on wiring and parts alone. It will come with 2 Kicker amps installed in rears seats. distribution blocks, wiring,RCAs, its all there. I will also throw in the stock rear seats as well in case you dont want the amps inthe seats.
- car is also completely dynomatted from top to bottom, front to back
-brand new AA auto headliner(better then OEM)
-engine compartment just painted gloss black by body shop.
-new radiator and windshield
There is a lot more I just cant think of right now. I will keep adding to this list as I go over the car once more. THis car is well built and not hacked at all. I take great pride in my work. I just want to build a new cars.(roadster) I need the engine and trans from this car though. if you have carb motor and trans then this would be perfect for a daily driver-strip car. Im looking to get $6,000 for it. it is well worth that all day long. Trust me. You are getting a lot here.
CarGuyDennis
137
12-06-2016 11:02 PM
