91 305 tbi 5 speed 3100
this car has had a lot of work done to it because I couldnt find outwhy it was purging, it ended up being a clogged cat. soo thats why alot of these things where done, it has new plugs,wires, distributor cap, rotor bug, coil, tps senser, new intake gastets, timing chain gears and chain,water pump, clutch pressure plate and throw out bearing non reman parts. and a new cat. but once i got it running and driveable i got ont he highway and at 65 it start shaking. so took it home, had bad ball joints replaced them tie rod ends center link, idle arm, and one ball joint was so abd it wallored out a spindle so replaced that, new drive shaft and u joints, ended up being a bent rim. soo im selling this car because ive caught my eye on something with really good milage, this car is mechanically sound runs fine now that i have a set of 15 rallys on the rear the tires are still good jsut the two rims where messed up. ummmmm im trying to think of what else. it has a new grant gt steering wheel, odometer says 80600 title says under milage rebuilt, soo i dont know it. its a clear title other then that. umm i have a eaton posi with 3.42s if someone makes the right offer. ive put alot of time in this car well really my ddad did he did all the work hes a tech for bobcat of stlouis hes been workong on car and heavy equipment since the 60s soo the work was done right it wasnt done by some 17 year old who didnt know what he was doing i was being tought on what to do, this car is my daily driver. the body has no large amounts of rust a few bubble spots in the paint one not even teh size of a dime, the other about the 3=4 inches right under one of the ground effects here are some pictures sorry there all i have taken witha friends camera
http://stlouis.craigslist.org/car/370883022.html
