[CA] Wanted 1992 Camaro cash in hand what do you have
Want a title? Post!
I would like something nice original owner or 2nd owner even better if you have the history on it not looking for a project prefer a manual z28 heritage but open to what you have not looking for a v6. Looking to buy asap and will travel for the right car at the right price.
Please respond with the specifics of your car as well as pictures
Car: 1990 Chevrolet Camaro Iroc Z
Engine: 427 Dart SBC
Transmission: TH 400
Axle/Gears: Ford 9" 4.11 gears
Re: Wanted 1992 Camaro cash in hand what do you have
Very meticulously maintained third gen Camaro. Painted synergy green with black stripes. This fully forged 383 SBC with a manual valve body th400 transmission with FTI Converter will make the perfect drag/Street rod. With a full spool Ford 9"with 35 spline axles and a curry rear housing with 4.11 gears. Qa1 rear coil over double adjustable suspension. Hotchkis rear control and trailing arm setup. Coil over conversion up front with a tubular k member. Weld rims and an extra set of rims for the rear with slicks to hit the track with. All msd electronics (6al ignition, blaster 3 coil, pro billet distributor and wires). This car has power mirrors, power seats, power windows, windshield wipers, stereo system, t tops. The 9.5:1 compression motor makes an awesome Street car and a maintenance free rig. With the suspension setup there is plenty of room to go faster if wanted. Absolutely mint car.Stored in a heated garage 24/7! Paint is 5 years old and I replaced every gasket around the doors, t tops, and rear hatch. Also put a new windshield in at the time because the original had some pits
