Installed a 2001 Delco Radio/CD w/ 7 band EQ
Car: 91 Firebird
Engine: V-6
I couldn't help it! I was at the junk yard looking for parts and this radio was in pristine condition just begging to go home with me. $35 bucks later and an evening with the dremel, it is now installed. All I can say is it sounds sooooo good compared to the stock delco that I repaired a few months ago. I also like how the lights now match the rest of the dash. Did I mention how awesome it sounds!
Car: 92 Firebird--02 Grand Prix GTP 2Dr
Engine: Poncho 400--3.8 Supercharged
Transmission: T56 6 Speed--4T65EHD
Axle/Gears: Open 10 bolt 3.42--Internal 2.93
Re: Installed a 2001 Delco Radio/CD w/ 7 band EQ
My 2002 GTP has that radio. I've also been planning on getting one for my 'bird when I get it running soon!
What does it look like in the day light?
It'll look right at home AND period correct in the 90's 3rd gen 'birds
Car: 91 Firebird
Engine: V-6
Overall the main part of radio is about 1/4" longer than the stock radio. The CD player is another 1/2" longer just at the top. So in all, the entire radio is about 3/4" longer than the original.
This radio was pulled from a 01 Grand Prix, so if your at the junk yard, be sure to hit all the Pontiac's, not just the Firebirds.
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
I want to do this conversion, but I need an aux modification to the radio and I need to do the steering wheel swap because i refuse to be content with driving my GTA without steering wheel controls.
I have the uk3 option in my car and I like my steering wheel controls very much.
Anyone know if I can swap a 4th gen wheel on a 3rd gen column without major mods? Or should I be looking for an entire column.
Car: 91 Firebird
Engine: V-6
I know the car I pulled it from had steering wheel controls. Not sure if it is directly compatible with older controls. Maybe someone on the boards can answer that has more experience with these radios.
Pretty cool.... but DAMN that radio screams cheap 90/00s chevy plastic garbage!!! BLEH
Nothing against you, I just have serious hate for the "Styling" Chevy went for back then..
The thing that's so sad about it is I personally feel the Delco third gen radios are leaps ahead nicer looking than those new Delco units... and they're pretty outdated themselves
Car: 85' TA, 99' 30th TA, 09 G8 GTX
Engine: 305HO L69, 350 LS1, 6.0L L76
Transmission: T5, Hurst 6, 6L80E
What rear plugs do you have? Would the 1985 radio male connectors be the same as yours? I have 3 connectors. A blue, white, and some other color manybe grey with a 2 prong additional connector. Is that what you have? My radio has recently kicked on the clock which stays on so long as the ACC fues is in the car.
I have blue and white which are speakers, I have black which is power and lights and I have gray which is for steering controls. Keep in mind though I think 1988 was the first year for these plugs in our cars
Car: 91 Firebird
Engine: V-6
I think you can buy an adapter to convert from 12 pin to 21 pin, so you can use the newer style radios.
http://replacementradios.com/gm-wiri...-a3-p-166.html
Car: 89 Iroc Convertible
I see those pontiac cd players all day long at my local yards.Just picked up a monsoon cd player from a 98 camaro in good working condition.The second picture is the delco cd player that I have in both of my Irocs.
It's a Buick radio.They came in early to mid 90's road masters and lesabres if your lucky enough to find one.The wiring is a gm standard 21 pin plug used from 89 and up.I have several of these CD players if your interested.The radios work but the cd mechanisms need to be refurbished
Sounds good. Thanks for the info. I'll have to splice in the 89 and up connector to work in my'88.
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
For the radio MY82ROC posted, keep a lookout for sloped front end style astro/safari vans. I have seen many with that type, for pontiac guys look for early 90s bonneville and you will get red lighting in the same unit.
It should also be noted for some reason that era of deck seems to pump out better sound then those newer bubbly looking GM units. Not only that they look better.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I put the same radio as the OP in an 88 GTA. The font matches the HVAC, the red backlighting matches the dash, and the rear plugs fit without any splicing. Unless you are intimately familiar with these cars, it looks factory stock. And the good news is that perfectly functioning ones are available for peanuts because they were used in all flavors of Grand Am's and Grand Prix's in the early 2000 era that now litter every junkyard. But it does not work with 3rd gen radio controls.
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
ASTRO 92 w/o remote multi-disc CD player; AM-mono-FM-stereo, w/o cass; w/CD player
ASTRO 93-95 AM-mono-FM-stereo-CD player
BERETTA 92 w/o remote multi-disc CD player; w/o cass; w/CD player
BERETTA 93-96 AM-mono-FM-stereo-CD player
BLAZER S10/JIMMY S15 92 w/o remote multi-disc CD player; AM-mono-FM-stereo, w/o cass; w/CD player
BLAZER S10/JIMMY S15 93-94 AM-mono-FM-stereo-CD player
BRAVADA 92 w/o remote multi-disc CD player; AM-mono-FM-stereo, w/rotary *****
BRAVADA 93-94 AM-mono-FM-stereo-CD player
CAPRICE 92 w/o remote multi-disc CD player; w/o Bose sys; AM-mono-FM-stereo, w/o cass; w/CD player
CAPRICE 93 AM-mono-FM-stereo-CD player
CAVALIER 92 w/o remote multi-disc CD player; AM-mono-FM-stereo, w/o cass; w/CD player
CAVALIER 93-94 AM-mono-FM-stereo-CD player
CHEVROLET VAN 92 w/o remote multi-disc CD player; AM-mono-FM-stereo, w/o cass; w/CD player
CHEVROLET VAN 93-95 AM-mono-FM-stereo-CD player
CHEVROLET VAN 96 exc. Express; AM-mono-FM-stereo-CD player
CORSICA 92 w/o remote multi-disc CD player; (AM-mono-FM-stereo), w/o cass; w/CD player
CORSICA 93-96 AM-mono-FM-stereo-CD player
GMC VAN 92 w/o remote multi-disc CD player; AM-mono-FM-stereo, w/o cass; w/CD player
GMC VAN 93-95 AM-mono-FM-stereo-CD player
GMC VAN 96 exc. Savana; AM-mono-FM-stereo-CD player
LUMINA VAN 92 w/o remote multi-disc CD player; AM-mono-FM-stereo, w/o cass; w/CD player
LUMINA VAN 93 AM-mono-FM-stereo-CD player, ID 12343194
S10/S15/SONOMA 92 w/o remote multi-disc CD player; AM-mono-FM-stereo, w/o cass; w/CD player
S10/S15/SONOMA 93 AM-mono-FM-stereo-CD player
SAFARI (GMC) 92 w/o remote multi-disc CD player; AM-mono-FM-stereo, w/o cass; w/CD player
SAFARI (GMC) 93-95 AM-mono-FM-stereo-CD player
TYPHOON 92 w/o remote multi-disc CD player; AM-mono-FM-stereo
TYPHOON 93 AM-mono-FM-stereo-CD player
I have that same exact deck with black trim and once again it came from a buick
I got my 1998 Trans Am radio with 7 band. The back plugs do not match the thick factory plugs on my '85. Do they make a way to adapt it?
Car: 84 Trans Am
So the 20 pin is the newer style. I saw the 21 pin being called that. Just want to make sure the link with the 20 pin is correct.
Car: 84 Trans Am
I could be wrong but I think 20 pin is a typo on the website. It was a 21 pin connector. Some if the buick/olds changed to a 32 pin in the late 90's, but that won't affect you if you're using the 4th gen style Pontiac radio.The link to that plug will work for all GM cars pre 89.
Bought this radio http://www.ebay.com/itm/281696562824?_trksid=p2060353.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
Got the 20 pin adapter mentioned above. Plugged in. It came on. Stations work, CD player works... Screen is not working. Shows no signs of being broken. Need to know if its broken or the fact that the plug in the back center has nothing plugged into it. Not Bose, and does not appear to be Monsoon. Just a Delco from what I can tell.
Car: 91 Firebird
Engine: V-6
Bought this radio 92 93 94 95 96 97 98 99 00 01 Pontiac Prix Am T A Radio CD Equalizer 16228082 | eBay
Your screen backlight is burnt out. Shine a flashlight at the screen and you should see the channels changing etc. I ordered my replacment bulb from Ebay, and it is an easy replacment.
This is what you need:
http://www.ebay.com/itm/PONTIAC-RADIO-DISPLAY-BULB-OEM-DELCO-/161720244123?hash=item25a747179b&vxp=mtr
Glad your cable worked.
That is the issue. I appreciate everyones help on getting this swap done.
no green
01-09-2016 09:22 PM
LastHopeRS
11-12-2001 09:54 PM
Willie
06-13-2001 12:24 AM
