1982 Recaro Electric Aerial Mast replacement?
Hi.
Can anyone please tell me the GM part number for a replacement aerial mast or a rebuilt kit with the aerial mast as part of it?
Thanks,
Fred
Thanks,
Fred
Car: 88GTA
Engine: 5.7TPI
Re: 1982 Recaro Electric Aerial Mast replacement?
classicindustries.com
http://www.classicindustries.com/pro...rts/g4825.html
G4825 - 1982-1988 F-BODY POWER ANTENNA MAST
This is an original GM replacement power antenna mast originally used on 1982-88 Camaro models. This is a power antenna mast only, and will fit and replace the original exactly. $105.99 ea
Or, read my post on Turbotransam.com and go that route.
http://www.turbotransam.com/forums/s...ead.php?t=7708
Axle/Gears: 10 Bolt 2.73 Open
You mentioned a rebuild kit....is yours working? Bent mast? All of the above?
I see. I had the same problem with mine. Last shutdown of the last cruise last season. Weather is just now allowing me to get to the repair.
https://www.thirdgen.org/forums/memb...ew-1988-t.html
I had mine rebuilt by a gentlemen in Texas. I have not reinstalled it yet, but he's been doing these for some years, so I'm not expecting a problem.
db057
08-11-2015 10:11 PM
