How to put an aux input in an 88-89 GTA radio
Old 12-10-2015, 03:04 PM
red88tagta's Avatar
Car: Restored 88 GTA
Engine: 5.0
Axle/Gears: Posi
I am getting out of the radio repair hobby. I thought I would pass along what I have learned.
Begin by removing the CDM module from the top of the radio (3 screws) Then completely remove the circuit board from the metal enclosure.
Turning the board upside down with the smoother side up, locate the MUX chip (Pictured) You want to cut the circuits from terminal 3 and 13. (Pictured)
Wire your aux input (From Radio Shack) like pictured and match up the wires to the pc board.
This will enable you to have an aux input for a remote location in your car. Choose the right length of cable for that. To put the aux on the face will be another how to instruction.
Attached Thumbnails How to put an aux input in an 88-89 GTA radio-1.jpg.jpg   How to put an aux input in an 88-89 GTA radio-9.jpg.jpg   How to put an aux input in an 88-89 GTA radio-2.jpg.jpg
Old 03-23-2017, 01:29 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: How to put an aux input in an 88-89 GTA radio
Ground wire leading from the AUX jack needs to get screwed - or soldered - to the case or under a circuit board screw.
IN THE PICS I posted here:
Orange and White/Orange = 1 channel ( Right )
Brown and White/Brown = 1 channel ( Left )
Traces can be cut at any point between the 2 solder points used for each channel. Just follow the trace connecting the 2 solder points ( example; Orange wire and White/Orange wires ) and find a good place to cut the trace that connects those 2 solder points. Traces cut are shown with very small blue arrows in the pics above.
Aux signal will interrupt FM and / or cassette, and AUX input will play when AUX plug is inserted into the jack. No need for a working cassette deck using this method.
Old 07-05-2019, 09:25 PM
FireBirdblooded's Avatar
Car: Taz
Engine: 572
Transmission: t56
Axle/Gears: 333
Wow
Your the best. This info is just what i needed. I hope when you say cut the trace , you mean scratch it out.
pirtekman
Car Audio
01-19-2014 09:18 AM
jeeps2creep
Car Audio
06-18-2006 12:29 PM
DSCole312
Car Audio
07-08-2002 09:33 PM
Quick Reply: How to put an aux input in an 88-89 GTA radio
