Stock radio identification and amp locations?
Car: Jeep Scrambler
Transmission: 4L60
OK, I have an 89' RS without all the hooplaa, just electric locks. I have the stock radio in it for now but would like to keep it stock but just put in the bose system with the amp. How do I tell if a vehicle came with the bose or not? Is it on the radio or can I look on the options sticker either in glove box or where ever it may be on other vehicles. What else would I need I see there is a amp relay in the schematics....so , radio , amp , relay and wiring harness? Oh, and where is the amp located at on the 89 rs's? It tells me behind the front right hand I/P, what is the I/P? Insturment panel? Thanks for any ifno.
For the record , I have an in at the local salvage yard so getting all the parts and peices not to hard to get as long as I get order in before anyone else see's it.
Car: 2004 Pontiac GTO
Axle/Gears: IRS 3.46
If I'm not mistaken all of the bose cars had speakers in the kickpanels. Also, you wont be able to use your stock radio with the bose system as far as i know. Which is the same reason you need a bose interface box when you get an aftermarket CD headunit.
Something about the different frequencys or something...i forget offhand. sorry.
in the Bose system there is one small amp mounted next to each speaker. the two front speakers are in the kick panels, and the two rear speakers are mounted in the trunk lid. if you want to convert a non Bose car to Bose, you should get a wire schematic for the Bose system. it uses a wierd grounding system, and requires a power and ground wire to each of the 4 amps.
Car: Jeep Scrambler
Transmission: 4L60
Now that was some good info on where and what things are. So now I read some where that you can convert the 89 as well as others radio style to the some size later model radios, can anyone lead me to that write up. I may have to go that appraoch,hell and get a CD player with it. LOL
colton_carlson
Mar 8, 2019 12:21 PM
db057
Aug 11, 2015 10:11 PM
