A small question
Old 08-24-2001, 01:47 PM
Federico's Avatar
A small question
Can i adjust the float level (screw and nut) with the engine turned off?
Old 08-24-2001, 07:42 PM
82camaro's Avatar
Car: 82 camaro SC
No because you don't have an fuel pressure. The needle and seat you are adjusting works against the fuel pressure. You also won't have anwhere for the fuel to go if you lower float level--it won't get sucked in a stopped engine.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Frozer!!!
01-19-2024 04:55 PM
Mickeyruder
09-02-2015 02:45 PM
fasteddi
09-02-2015 10:29 AM
theurge
08-21-2015 12:46 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: A small question
