fuel pressure ???????
Old 05-23-2002, 02:21 AM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Axle/Gears: stock/3.42
I just installed the 1400 edelbrock and aluminum intake,dist,etc. When i hooked up the fuel press. gauge to one of the outlet ports on the regulator, i cant seem to adjust under 6 psi. It says to run a larger return line to the tank if this happens. Will it hurt to just leave it alone seeing that the edelbrock calls out for 6.5 psi. as the max press and the car runs great? :
Old 05-23-2002, 02:46 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Just try it and see. Sorry if that sounds obvious but what else can you do?
92camaroJoe
07-29-2023 07:57 PM
R3500
08-17-2015 12:16 PM
wayshegoes
08-17-2015 12:00 PM
92camaroJoe
08-13-2015 06:07 AM
Kaweh
08-09-2015 02:54 PM
Quick Reply: fuel pressure ???????
