Holley 600 need re-jetting?
Old 04-02-2007, 05:11 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Ok I posted up a lill while ago about getting my carb re-built and I decided to do it myself, I went over it with a tin of thiners, Carb cleaner (preshure pack), paintbrush, tooth brush and 5 hours, it came out like new.
My problem it that it is running VERY ritch now and the idle mixture screws are all the way in if I screw them out it gets worse, I can smell the raw fuel when it is idling but if I screw the throttle on I get a cloud of black smoke.
What jets should I run in it? I think they have a 5 on them ATM.
The Holley was of a 69 camaro but i duno the engine size.
Old 04-05-2007, 12:11 AM
84H.O.Trans Am's Avatar
Car: 84 Trans Am
Axle/Gears: 9in 4.30's
Re: Holley 600 need re-jetting?
not sure how export cars are but did that used to have a Computer controlled q-jet and distrobuter..if the dist. is still computer controlled it could definatly cause you running problems and the timing would be all out of wack...
why did you switch out the stock q-jet..i did a little work to mine and the car ran awesome..14.4@94 on L69 305 with just headers and exhaust..
Old 04-06-2007, 07:07 PM
VenomX-87's Avatar
my Q-Jet was getting 9MPG around town, it was imported back in 87 from the US, i guess it had a cc carb at one stage but it don't now. The Q-Jet (matching the numbers up) is off a 70's GMC truck (Emissions era but not cc) and it is not a cc distributor it is a HEI one.
Old 04-06-2007, 07:10 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Hows the float adjustment? fuel pressure?
Old 04-06-2007, 07:13 PM
VenomX-87's Avatar
i don't know about the fuel pressure cos i don't have any way of reading it, I have a block mounted pump (no return) duno if there is a eletric one.
F.I. 57 Belair
08-23-2021 01:09 AM
RedLeader289
05-28-2019 01:47 PM
Royal_Z
09-30-2015 08:45 PM
dusterbd
09-29-2015 08:40 AM
makaveli09
09-15-2015 10:43 AM
Quick Reply: Holley 600 need re-jetting?
