ALLOY = Excellence!
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
ALLOY = Excellence!
Just thought i'd throw it out there, Alloy aka Dan recently modified my T-56 tailhousing for speedo drive. Excellent service, very fast turn around time and most of all very quality work. If you are thinking about having this done you won't be disapointed.
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Re: ALLOY = Excellence!
Yes, ALLOY is good people. Dean!
Car: 89 iroc-z
Engine: 5.7 tpi
Transmission: soon to be t56
alloy is gtg.. he also did this mod to my tail shaft... work was great and the turn around time was outstanding. i recentently had some trouble with my speedo gear... he directed me in the right direction and gave me a heads up on wear to get the parts i needed... his communication is outstanding and he is just a straight up good guy that does great work and is very knowlegable.
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
.Thanks guys. I'm glad I could help with your projects.
Car: 87' IROC
I also recently had alloy do the conversion on my tail housing. Excellent work at a fair price. Dan is easy to work with and is genuinely interested in my project. I would do business with him again.
You can see his conversion just under the green masking tape.
Alloy, also converted my T56 to a mechanical drive speedometer. I usually dont send money and parts to shops until I receive services, but I could tell from all of his references and after talking to him that there were going to be no issues. He followed through just as he said he would and also answered all of my questions that assisted me in my installation. I truly enjoy hot rodding because of people like Alloy.
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
I also had mine converted by Alloy! the quality and workmanship is second to none. I had a problem with the inner portion of my factory speedo cable being too long to go into the VSS. I PM'ed alloy at which point he focused all his effort on helping me fix the problem. He also gave me his cell number where for a few days I picked his brain and sent pictures about different things. He gave me a few ideas, but in the end the problem ended up NOT being anything on his end at all. He recommend me the correct speedo cable, it was installed and everything works great. I cant say enough good things about Alloy, his workmanship and his willingness to help out! Great guy, and great product!
1 Post
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
If no one minds me asking, how much did this service cost? I've been contemplating a t56 swap but want to keep the cable drive to my speedo intact. Thanks!
1 Post
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
The final product looks fantastic. For those of us not familiar with the changes, do you have some pics showing some of steps without giving away any secrets?
Car: 87 IROC-Z28
I machine the housing and epoxy in a sleeve I designed and make. My conversion uses stock gears that are readily available. I've done just over 50 of these now since I developed this in 2008. I wanted a T56 in my thirdgen but knew I needed a speedometer drive, so after much time and checking I came up with this.
I'm glad that I can help others with their projects. Its feels really good to read what others say about me and my conversion. Thanks to all of you for your kind words.
Dan
www.t56cablespeedometer.com
Dan
1 Post
Car: 88 irocz
Engine: b2l 350
Thanks for clarifying a few things. For some reason i thought you were modifying the original opening. Now if i could figure out how to connect your mod to a Ford cable drive speedo i can start planning a t56 swap for my F-100.
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
+1 for Alloy, fast turn around and a great guy. Really helped me out!
camaro1185
10-26-2015 06:51 AM
TheCardinal
Interior Parts Wanted
10-09-2015 09:43 PM
