1989 Convertible Top
Old 06-21-2011, 01:26 AM
3rdGenLover0203's Avatar
Car: 89 Vert RS
Engine: 5.0 tbi
Transmission: 5 Spd
Hey all. I am new to the 3rd Gen Convertibles. Recently picked up an 89 Convertible and have no clue how to operate the top. Any help on this would be very much appreciated!
Old 06-22-2011, 10:04 AM
jstanfi1's Avatar
Car: 1992 T/A Convertible
Engine: LB9 305 TPI
Re: 1989 Convertible Top
Pretty simple affair, assuming its a standard ASC convertible. First, there are two latches above each of the two sun visors. Pull on the handle and turn it 180 degrees to release the latch, and repeat for the other side. Then, with the car in park or not running, pull the handle that is embedded in the rear panel of the interior behind the drivers seat. It's close to the top, just below the cover for the top storage. This will release the top from the cover. Pull the back of the top up, grabbing firmly just below the rear window, and hold it up. Now, hit the small switch that was near the handle inside the car, and the entire storage cover will pop open. You can now fold your top down into the storage well, being careful to avoid crumpling the rear window (this is usually only an issue if someone stored it incorrectly in the past). It's a manual top, so depending on condition in might need some help stowing correctly. I frequently have to push one of the bows in my top towards the rear of the car to get it to seat correctly. Finally, shut the lid to completely conceal the top.
Being a manual top, it's a little more work than some newer cars, but it's also a very nice, finished look with the hard storage cover and there's no motor to break, etc. Enjoy your third gen 'vert!
Old 06-23-2011, 10:48 AM
Car: 89 Vert RS
Engine: 5.0 tbi
Transmission: 5 Spd
I am missing some parts and I think that the switch you are talking about is on one of them. I am missing the piece that goes over where the seat belt comes out of. I have seen pictures of a switch being on it but I am not sure if that is just the 90-92 model or what. I can not find a handle anywhere unless you mean the one right under where the pin for the top goes into the cover. All of that is un hooked and just hanging there. Need to put a little work in.
Old 06-24-2011, 10:01 AM
little8camarors's Avatar
Car: 92 Camaro RS TTop,91 Camaro RS vert
Engine: 305 TBI V8
The tonneau switch would be in between the window switches unless it is a 92 only (those are the only ones with the switch near the 5th bow release handle where it should have been). First undo the latches at the front. If your 5th bow relase handle is missing or not working open the trunk and look for the release under the tonneau cover and turn it by hand then lift the rear of the top. If your tonneau release button is missing or not working and you got the rear of the top up, fold the rear seats down and look for a cable with a loop on each side sticking out toward the trunk pull them toward the trunk, you should hear the tonneau release but you may have to pull up on the tonneau lightly at the same time.
Old 06-24-2011, 11:44 PM
Car: 89 Vert RS
Engine: 5.0 tbi
Transmission: 5 Spd
So the switch in the middle of the window switches operates the cover and the trunk? I have only had hatchbacks before this and it operated the hatch. My switch is not working at the moment.
Old 06-25-2011, 12:13 AM
Engine: 305 TBI V8
I'd believe that like most verts you don't have a power trunk release, that switch location and wiring was used for the tonneau switch and trunk was key(as my 91 is) only but I could be wrong.
Old 06-25-2011, 01:33 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
A "search" will find you tons on the subject. Check out my post (post #32) in this topic link . . .
https://www.thirdgen.org/forums/conv...upplement.html
. . . and this topic . . .
https://www.thirdgen.org/forums/conv...-top-down.html
Forget everything you've experienced with how a hatch back operates. This is a fun new ball of wax. You now have a trunk instead and it is not remotely released. That operation now belongs to the tonneau cover. And in your car, that switch takes the place of the one that used to operate the hatch. It should look like this . . .
. . . and in your ride it is in between the power window switches. (Note; I've ditched the ugly floormats!!! LOL)
To release the front of the roof, use the right & left release handles. Note; after you've put the roof down, be sure to fold their handles back down before you close the tonneau cover . . .
The handle that releases the rear of the roof is on the left side of the tonneau cover. Pulling that handle opens a spring clip releasing the roof's pin. Pulling the handle will allow you to lift the back of the roof. It should look like this . . .
. . . (note: some older models used rods instead of a cables to operate the srping clip but the principal stays the same.)
Here's a close-up of the spring clip . . .
Old 06-25-2011, 01:51 AM
Axle/Gears: 3.08
1 - Lower windows. Release the 2 front roof latches. Release the 1 rear latch with the handle on the side of the tonneua cover.
2 - Lift rear of roof.
3 - Release the tonneau cover with the switch on the console. Lift the tonneau cover up out of the way. On some, it may help to press the switch and lift cover at the same time.
4 - Carefully lower roof down onto the rear tray. Be sure to support the roof on it's way down (or up) evenly. Don't let it twist or bend by only lifting on one side.
5 - Roof is down. Front latches handles also folded down. Nows the time to lower tonneau cover. Be sure to latch it back down tight on both sides.
Putting the roof back up is pretty much just doing the opposite. With regards to the rear roof pin . . . when locking it back down into the tonneau cover, I like to put one hand on the roof over the pin, and then press hard with my other hand over my first (hand over hand) to lock it down. That way I can press down fairly hard but not actually on the roof itself. Be sure it locks in tight.
Old 06-25-2011, 02:06 AM
Axle/Gears: 3.08
You can still release the tonneau cover using the back-up cable releases. There should be one for both sides. These are meant to be a temporary solution until you get the switch operated method working again. Your problem may be the switch or the solenoids. Be sure there's power.
You can see the cable in these pics. Kind'a looks like a fishing leader with a loop on the end (bottom right on this pic) . . .
Old 06-25-2011, 09:49 AM
Car: 89 Vert RS
Engine: 5.0 tbi
Transmission: 5 Spd
Oh man. thank you so much. I've been looking all over for pics like that cause my handle is just hanging there and the handle on the inside is broke off. Beautiful car by the way. Can't wait till mine is that clean. I think you just answered and showed me everything I need to know. Just got to find me some parts now!
Old 06-25-2011, 12:28 PM
my82roc's Avatar
Car: 89 Iroc Convertible
What parts do you need?Ive got a bunch of spare vert parts around here
Old 06-25-2011, 04:34 PM
Car: 89 Vert RS
Engine: 5.0 tbi
Transmission: 5 Spd
I need the cable and handle to pop the top and the pieces that on by the cover that the seat belts feed thru. A top would be nice as well but I know they get pricey. Oh ya, a ls1 and t56 6spd as well! lol
Old 07-26-2011, 07:39 PM
Dave Caribardi's Avatar
i also read your great response (w/pics) on vert top operation. I just bought a '89 Firebird Vert. I have the trunk release button on the dash & it has trunk graphics, but nothing happens when I push this switch, so I have been using the 2 pull cable loops to release the cover. do you think the trunk release button being substituted for the top cover release is a common rule for Firebirds too (ASC vert), I do have solenoids on each side down on the floor right behind the rear door posts.
Old 07-26-2011, 09:55 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Is your trunk pull-down motor in good operating condition? If not fix it. The tonneau solenoids will not work if it thinks the trunk is open.
Lon
Old 07-28-2011, 03:40 PM
RagRoc's Avatar
Car: 88 IROC Convertible
Transmission: M5
Axle/Gears: 9-bolt 3.45
That is a valuable piece of information........it took me a week to find that on my own.
Contact Lon if you need pulldown parts.
Old 08-09-2011, 11:36 PM
ken0hki's Avatar
Car: 91 TA GTA, 88 Camaro Covnvertible
Engine: TA 350 Supercharged, Camaro 350
Transmission: TA 700R-4, Camaro T5
Axle/Gears: 3.23 Posi in both cars
you would not happen to have the rear quarter panel side moulding for a vert would you?
Old 08-10-2011, 05:38 PM
iroczVinnie's Avatar
Car: 89 IROCZ vert
Engine: 305TPI
this should be turned into a sticky on a practical guide to operating the convertible top.
Old 08-11-2011, 03:20 AM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
You are perfectly right Vinnie. It should be a sticky. Hope everything is good for you.
Old 08-11-2011, 05:21 PM
hi Lon,
thanks for your input on Verts (I have a factory '89 Firebird), would you have a replacement seal for the 'B pillar that mounts to the top (passenger/left side - seals rear edge of window to top)?
also in your response on operation the picture shows a sketch of the release set-up & makes reference to the owners manual supplement for tops, do your have one for sale, or could you copy one for me? (I also need the normal owners manual). my trunk release button is on the lower edge of the dash (above a/c controls), I assume from your info, this is my tonneau cover release (does not work). how do your remove the big/black plastic trim piece from the tonneau lid for re-painting? thanks for all your help & if you have the parts I need, please email me - davidcaribardi@yahoo.com
Old 08-11-2011, 05:22 PM
hi Lon,
Old 12-16-2011, 01:54 PM
Crusher2011's Avatar
Car: 1992 Trans Am Convertiable
Engine: 305 5.0l
Axle/Gears: 4.10
Does anyone know where I can get a black convertible top for a '92 Trans Am for a good price? and i also need to find a gold honey comb rim for the front at a good price, any ideas?
Old 12-16-2011, 05:01 PM
ken0hki's Avatar
the switch does release the top, not the trunk. however, i replaced my switch with a spare power window switch and added the trunk wiring. rocking it forward releases the top, and rocking it back releases the trunk.
Old 12-16-2011, 05:36 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
great idea!i just added the trunk release solinoid.i plan to hook the switch though the ignition switch so if i leave my top down my trunk is secure.
Old 12-16-2011, 06:33 PM
ken0hki's Avatar
if your car is an automatic, add a relay and connect it to the wiring that controls park. that way it will not allow you to accidentally open the trunk or roof without placing the car in park first.
Old 12-16-2011, 09:21 PM
lonsal's Avatar
new top: topsonline.com
new GTA gold rim: Classic Industries, otherwise check the ads on TGO or eBay
Lon
Old 12-17-2011, 10:55 AM
Engine: 305 5.0l
Axle/Gears: 4.10
thanks lon, one more thing, my tops switch isn't working, im not getting any power to it either, could it be the siloniod when out? or is there a fuse some where for it, anything helps, thanks
Old 02-29-2012, 12:24 AM
Dalakian's Avatar
I have an off topic questions:
The rear latch on my 1991 Firebird is missing and I don't know where to buy a replacement. Tried junk yards but none of them have it. Is there any place that I can order it from online?
Right now it's being help by a metal wire creating a huge gap between the convertible roof and the body of my car.
Thanks for you help!
Old 04-16-2012, 10:33 AM
lonsal's Avatar
Sorry I didn't see this earlier. Contact me I should have the part(s) you need.
Lon
Old 05-29-2012, 09:46 PM
mjwjr_wa's Avatar
hello Iam in the same boat bought and 88 convert that the guy had torn apart then then got divorced so i had no idea how the tonnou cover should look like now is the rear shoulder straps an option and does the tonnou (spelled wrong) seal seal against the carpet trim or ?
Old 05-29-2012, 09:48 PM
mjwjr_wa's Avatar
also just broke the top frame part that bolt on the LH side its a cast medal piece #3237 would you now how to get one
Old 06-15-2012, 11:47 AM
NCIROC's Avatar
Car: 1989 IROC CONVERTIBLE
Transmission: AUTO
Axle/Gears: Dont know
MY TONNEAU RELEASE SWITCH JUST STOPPED WORKING. YOU SEEM TO BE THE TOP GURU.MY TRUNK PULLDOWN IS WORKING.WHERE DO I START? THE CAR SAT UP FOR A WHILE AND I'M THINKING THE SOLENOIDS MIGHT JUST BE STUCK
Old 06-15-2012, 11:53 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Sorry to highjack but Just a FYI. I have a 89 camaro vert top frame (no cover) for sale.
It has some parts missing sooo it will be cheap (case of pepsi?).. I'd prefur it picked up because it'll be a mess to to ship im sure.
PM me if anyone wants it...
Still have this as of 3/11/13
Old 06-15-2012, 12:21 PM
lonsal's Avatar
Based on our telecon, it is most likely the trunk pull-down motor is the place to look for your problem. Once you remove the trim panel you'll see the angle bracket that is attached to the screws that hols the pull-down motor too the frame of the pull-down mechanism. On that bracket is the white switch that senses that the pull-down unit has fully closed the trunk. If that switch is not being pressed, your tonneau switch will not work. As I recommended, get a 1989 Camaro Service Manual. They are available new online at www.helminc.com or used on eBay.
Lon
Old 08-28-2012, 10:35 AM
richr's Avatar
Re: 1988 Convertible Top
Does anyone know how the body drains run? down where the rear speakers are water runs into the rear seat floor pan! any ideas?
Old 02-03-2013, 09:00 PM
James1995's Avatar
hey just got my first car, 89 camaro convertible, and i'm experiencing some problems. When i first got the car, the top was fine, it worked without a problem. then randomly one day i decided to put it down and it doesnt fold down properly. it doesnt go down all the way and it seems just weird. im not sure what to do about it, id appreciate any help as im very car stupid.
Old 02-03-2013, 10:18 PM
NCIROC's Avatar
Transmission: AUTO
SOMETIMES WHEN YOU FOLD THE TOP DOWN,THE BAR GETS IN THE WAY AND THE TOP WILL NOT GO DOWN ALL THE WAY.JUST LIFT THE BAR WITH YOUR HAND AND THE TOP WILL GO DOWN.IF THAT DOESN'T WORK,I DON'T HAVE AN ANSWER
Old 02-05-2013, 04:06 AM
ken0hki's Avatar
Can you post a photo in the stuck position? That might help us to see the problem.
Old 03-04-2013, 06:57 PM
James1995's Avatar
these are some pics sorry for taking so long havent had a noncold day in awhile
Old 03-04-2013, 07:06 PM
NCIROC's Avatar
Transmission: AUTO
when mine does that,i just lift the top enough to push all that xtra material to the back and the bar will go with it.if that doesn't work,i'm confused.
Old 03-04-2013, 08:21 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
First thing I notice is that the handles that lock the top when up. Fold them back around and it won't crack the plastic panel behind them when cover goes down. As for the rest really need to see step by step of you putting it down.
Old 03-04-2013, 09:23 PM
NCIROC's Avatar
Transmission: AUTO
i looked at it again enlarged and it looks like the part of the top that is all folded up is in the way.i lift the top up and push all those flaps toward the back of the car.there is a bar in the middle of all those flaps that must also be pushed toward the back.when you get all that top material out of the way thr top will lay flat.
Old 03-04-2013, 09:50 PM
  #42
lonsal's Avatar
The problem is your "flip rods" are broken or missing. In lieu of replacing these rods that are no longer available, when you lower the top raise the #2 bow as you fold down the top. If your rear seatback were up you would see that the top fails to clear the top of the seatback. The bows are numbered #1 thru #5 starting with #1 (which has the latches that attach the top to the top of the windshield. #2 bow is the very next one toward the back of the car. It must be raised up as you lower the top or the entire top assembly will be folded incorrectly as you are experiencing. Normally the flip rods take care of lifting the #2 bow. The attach from the side rail to the #2 bow.
Lon
Old 03-04-2013, 10:56 PM
  #43
Benc1's Avatar
Flip rods not on all 89's. Mine never had them. Talked to top down solutions about it. Way I understand it they came on later cars.
Old 03-04-2013, 11:09 PM
  #44
lonsal's Avatar
There will be a small hole on the side rail of the frame and the rod that connects to the #2 bow if it had the flip rods originally.
Lon
Old 03-11-2013, 05:49 PM
  #45
James1995's Avatar
I thiink i might have found the problem after fiddling around with some of the panels, fixing them so they dont fall out. i noticed the side that is the problem is missing a bolt that the other side has, the right side only has one while the left has two. i dont know what to call all these pieces but it looks like the bar its connected to is meant to slide i will get a picture up soon
Old 03-16-2013, 01:40 PM
  #46
James1995's Avatar
fixed the probelm
Old 03-17-2013, 07:10 PM
  #47
lonsal's Avatar
Did you ever replace the cast broken frame piece? I have several top frames and have the part.
Lon
Old 03-17-2013, 07:13 PM
  #48
ken0hki's Avatar
Lon
I am looking for the rear curved piece with hook that the top attaches to and latches to the deck lid.
Old 03-17-2013, 07:42 PM
  #49
lonsal's Avatar
Yes I have several.
Lon
Old 03-17-2013, 07:51 PM
  #50
ken0hki's Avatar
Yes I have several.
Lon
how much and do i order from your site?
Quick Reply: 1989 Convertible Top
