So you guys want a bolt in all aluminum 3 core radiator?
#552
Re: So you guys want a bolt in all aluminum 3 core radiator?
No issues, I live in Houston Tx, it cools it better than the stock radiator in the summer. Sitting in traffic with the fans on it brings it down to 185, Once I start driving it brings it down to ~180, in 90 degree humid Houston weather. I thought the extra thickness of the radiator might pose a problem, but I have not had an issue. It was well worth the $$.
#553
So, Champion 3 row : yay OR NAY?
On second thought, ill just get the 2 core.
#554
Hey if any of you guys are interested, I've got a brand new, Champion 3-core (CC951), that's never been installed or run, that I'd be willing to sell for $145 shipped to anywhere in the lower 48. I checked Ebay and my asking price is like 20 bucks cheaper than the cheapest listing on there. It's in perfect condition. Just never used it and ended up going with a different radiator. Anyone who's interested, feel free to send me a PM on here or you can email me at Nosferatu6979@msn.com. Thanks! P.S. I have some pics of it if you'd like to see it before deciding.
#555
Anybody put a Champion 3 or 2 core in lately?
My rad started leaking so its time to get a new one. Either grab the plastic cheapo $80 spectra, or upgrade a bit. But if Im paying twice as much for the Champion 2/3 core, I expect it to not have any issues.
So, lets hear from ya.
#556
Hi Gang, I just bought the champion 3 core with the aluminium shroud and am having a problem getting it to fit. Issue isn't the rubber supports and I know to shave them down. IT is the piece that sits on top and holds it all together. In my 89 TPI 305 the piece that holds in together is slightly curved and narrows in the middle making it tip up in the back regardless of what I do with the mounts. Is there a custom piece that you can buy that fits properly? Thanks for any help you can provide
#557
Anybody tried the Eastwood triflow? https://www.eastwood.com/triflow
#558
Axle/Gears: 10 Bolt 2.73 Open
I have not, but I've been wondering about them. It would certainly increase time in the radiator, but doesn't that restrict flow?
#560
Car: Teal 92 Z28
Engine: 5.7
I know this thread is about the fans, which I am going to follow the advice given here but I was also wondering about the water pump. From reading around it is stated that my OE is pulling over 10 HP away from my motor (92 Z28 350 with 94k miles) what are you guys doing for your? Thank You
#561
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
This thread is about Radiators, Electric water pumps will use the least amount of HP but For a daily driver I would stick with a well known Manufacture and use a standard belt driven unit.
#562
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Nearly 10 years running my champion/victory radiator on my 412" blown SBC.
No issues.
-- Joe
#563
Will this 3 core rad fit my 88 Firebird Formula 350?
Correct holes for the trans cooling lines?
Will the twin fan set up fit?
Specifictions:
Core size approx : 26.2"*16.9"*2" (665mm*430mm*52mm) --- 3 ROW
Overall size approx : 31"*18.7"*2.76" (785mm*475mm*70mm)
Upper inlet: 1.25" (32mm)
Lower outlet: 1.5" (38mm)
Core and Tank: All Aluminum
It's not that expensive, and available in my country...
Thanks!!
Specifictions:
Thanks!!
#565
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
haven't heard of that brand, so I apologize I can't give it any comments.
#566
Specifictions:
Thanks!!
Specifictions:
Thanks!!
There's no senor or anything on the existing radiator, although I can see the hole is closed one way or another..
#567
Car: 86 Z28
That goes to your over flow tank.
#569
Car: 86 Z28
Gotcha I am not sure I'd have to see it in person.
#572
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Pipe plug? I am not sure what th thread is, or it may come with the plug
#573
Car: 86 Z28
It seems like it would be for a sensor, but it doesn't seem to be the correct size but maybe it's the picture. Id find a plug and use sealant if it goes into the water jacket.
#576
Car: 1982 Z28
Engine: LC9
Transmission: AR5
A three-year bump! Installed the Champion three-row radiator on my LS-swapped 1982 Camaro, and no issues other than what has been mentioned about trimming the upper and lower rubber snubbers (or make your own). OEM upper shroud and single fan went in perfectly.
BLACK Z (06-22-2023)
#577
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Holy crap, hard to imagine a post I made 14 years ago has almost a quarter million views lol
#579
I'm still looking for that perfect radiator. The one where its a direct bolt in, 3 row or better, and nothing has to be trimmed. This car doesnt have any body modifications, holes drilled into the metal, plastic pieces trimmed, etc, and to have something that bolts right up would be special.
#580
I'm still looking for that perfect radiator. The one where its a direct bolt in, 3 core or better, and nothing has to be trimmed. This car doesnt have any body modifications, holes drilled into the metal, plastic pieces trimmed, etc, and to have something that bolts right up would be special.
IROCZman15 (09-24-2023)
firbird
Fabrication
40
08-30-2010 02:31 PM
FireHwk
07-28-2009 12:13 PM
