Fan broken?
Old 07-11-2012, 05:25 AM
tyrell418's Avatar
Fan broken?
Well i just bought a 92 z28 with the 350. For some reason the fan dosent turn on unless i have the A/C on, im gonna get it checked tomorrow but was wondering what your guyses opinion is?
Old 07-11-2012, 08:50 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
Re: Fan broken?
have you waited for engine to warm up to where thermostat opens up? Upper hose will get Hot, that's when fans should kick on.
Old 07-11-2012, 09:20 AM
tyrell418's Avatar
Re: Fan broken?
Yep, nothing.
Old 07-11-2012, 12:25 PM
Arvizu9618's Avatar
Re: Fan broken?
Prolly a bad Coolant Temp Sensor which sends signal to ECM
Or Prolly no Ground signal being sent to fan relay
I wired up my stock dual fans with this: http://www.amazon.com/Hayden-Automot.../dp/B000C3DD7M
bypassing the CTS and the ECM problem I had. I was lucky to find one on Amazon for around $10 bucks at the time. Works like a champ.
Old 07-12-2012, 03:25 AM
tyrell418's Avatar
Re: Fan broken?
Alright thank you, my mechanic and i are gonna check it out tomorrow
sheachopper
07-31-2019 11:27 AM
apie2546
10-16-2016 02:24 PM
no green
01-09-2016 09:22 PM
Reid Fleming
10-10-2015 09:56 PM
Fanatic1074
10-02-2015 03:47 PM
Quick Reply: Fan broken?
