NEW adapter board for megasquirtII to 86-88 tpi cars
Old 06-18-2009, 11:44 AM
  #101
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Re: NEW adapter board for megasquirtII to 86-88 tpi cars
you do not send your ecm enywhere then garage, MSII and adapter you can find on Diyautotune.com and all software + manual can be found on www.megamanual.com
best regards
Old 06-20-2009, 08:08 AM
  #102
WASyL's Avatar
ok, i've plugged MSII into harness and with configured MegaTune wanted to burn settings to it, MegaTune does see MSII, it does succesfully confirms connection; but Battery indicator states Battery LOW, and when i oppened VoltGauge in MSII is shows 0V i'm wondering if its something wrong with adapter or MSII or is it some sort of setting that i don't know about ??
best regards
Old 06-20-2009, 11:06 AM
  #103
WASyL's Avatar
ufff, it works, sticker was saying Firmware v2.8880 but was actualy 2.6, i've upgraded it to 2.89 and it works with no problem
best regards
Old 06-21-2009, 01:16 AM
  #104
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Keep us updated! I want to know how it runs!
Old 06-21-2009, 06:12 AM
  #105
WASyL's Avatar
yesterday i managed to fire it up with some basics maps found on internet (close setup except injectors and bigger heads) and car runs quite smooth (even with NB), tommorow i'll be mounting LC-1 and starting to tune as on next weekend i have racing event and want to brake 12's (on street not strip), i'll put my spec and config with maps propably on begining of July
best regards
Old 06-29-2009, 10:01 AM
  #106
Toehead's Avatar
So with this adapter board, what is the best ignition circuit to use? (Hall or VR)
Old 06-29-2009, 04:25 PM
  #107
efi-diy's Avatar
For ease of installation use the GM module distributor reference high output and the Hall/opto input.
Old 06-29-2009, 04:44 PM
  #108
Toehead's Avatar
Ok, that was my suggestion as well. Thanks
Old 07-01-2009, 06:30 AM
  #109
WASyL's Avatar
first thing is i must say i'm such a dumbass, when i fiered a car i thought i started it with MSII but i was wrong - i asked my brother to connect MS to harness and hide it begind the dash, but i havn't checked that and after a day i found it was stock ECM - he didn't know which one is which and he choosed stock one without asking, so i replaced it with MSII and wanted to start with it, but it wouldn't so i opened Megatune and checked what is going on when cranking, and it is not cranking, RPM gauge shows 0, all others show values except this one, cranking indicator shows "No Cranking", after suggestions from Toehead i checked if jumpers for ignition but they are ok, all settings in MT seem to be ok - checked by Matt Cramer, he suggested to remove Pin B on ignition module and check if i get spark so will do this, but maybe any other ideas what to check ??
best regards
Old 07-01-2009, 01:01 PM
  #110
WASyL's Avatar
ok as Matt Cramer asked, with pin B no spark at all, with removed - car starts without any problem (except it needs a bit of tuning), what do i need to do or replace to make it work with pin B connected ??
i especialy bought TPI adatper to avoid doing any wiring
best regards
Old 07-01-2009, 05:58 PM
  #111
efi-diy's Avatar
Matt from DIYautotune is working to support this issue with background support from myself. Today being Canada Day most folks are enjoying our national holiday.
It appears that the HEI module is not getting a timing reference.
Old 07-05-2009, 05:45 PM
  #112
Toehead's Avatar
any updates?
Old 07-05-2009, 06:53 PM
  #113
efi-diy's Avatar
I'd expect we'll get an update from Wasyl/Matt tomorrow. Friday was a day off for most folks in the US and I think DIYautotune was closed.
Old 07-06-2009, 09:28 AM
  #114
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
hey guys... sorry i've been out of the loop for so long. just completed a retarded 8 month project at work so i get to have more normal hours again. i've been fighting with my car trying to get a tune to work when i decided to slap my other computer back in and discovered there is actually something wrong with my car. hoping within the next week to have it running well again so i can get back to the megasquirt.
perhaps i misunderstood an earlier post, but with the vss not passed through on this board, will my speedo and cruise control not work?
Old 07-06-2009, 01:25 PM
  #115
efi-diy's Avatar
The 86-89 ecm has a vss input but the processing/conversion etc. is done elsewhere - you might want to verify this I think its done by the DRAC module. So your speedo/cruise should still work. The later ECM's (7730)integrated this function.
Old 07-06-2009, 01:28 PM
  #116
thunder85's Avatar
Engine: 5.7L w/hsr
excellent.. i just havn't gotten it running well enough on the ms to drive the damn thing. once i nail down my fuel pressure issue i will be back in business.
Old 07-15-2009, 01:22 PM
  #117
SebringZ's Avatar
I have some questions concerning this mod(adapter). I have an 87' TPI setup. It's MAF regulated and some parts are modified. I will soon be running forced induction(suerpcharger, moderate boost). To be specific. This is a plug and play setup? I get the ECM which is basically(rebuilt) to megasquirt specs and Download the software and tune it accordinlgly? I was away from the car stuff, so alot has escaped me, but im getting back on it. I'm located in New York and if the product works as I think it does, I'm interested. How much for the complete kit and what's included? What do I need to send and how do I go about information? Thanks
Old 07-15-2009, 07:43 PM
  #118
efi-diy's Avatar
See mid message body for your answers
This is a plug and play setup? The adapter board allows you to plug a Megasquirt into your factory harness without have to chop the harness up.
I get the ECM which is basically(rebuilt) to megasquirt specs and Download the software and tune it accordinlgly? << Not quite - the megasquirt replaces the GM ECM outright.
You either buy a pre-built megasquirt or a kit which you assemble. Then you download the tuning s/w (free) and install a tune up for the TPI application - then fine tune from there. More than one person has a TPI car running on MS so you can get a starting tune from them.
email sales at www.diyautotune.com
they will help you out to get what you need.
Old 07-16-2009, 02:13 AM
  #119
WASyL's Avatar
ok a small update on what is going on, Matt Cramer found out that even when adapter is used some of aftermarket ignition modules won't work so there is still need to make this circuit with relay
i've done it yesterday evening and it works, once again thanks for every one for help and special thanks for efi-diy for making this adapter and all the support he gave
best regards
Old 07-16-2009, 07:27 AM
  #120
thunder85's Avatar
Engine: 5.7L w/hsr
which after market ignition module are you using?
Old 07-16-2009, 02:05 PM
  #121
efi-diy's Avatar
What we found out is some HEI ignition modules won't fire during cranking unless they are on fixed timing. Quick test for this with the MS installed if it won't start unplug the set timing connector.
The fix for this is to wire the ECM connector pin C9 to the starter solenoid circuit that is hot only in crank position via a 1 amp fuse. It was easier for Wasyl to wire an external relay than find/reuse an extra ECM terminal - kind of hard to come across in Poland.
Old 07-20-2009, 06:56 AM
  #122
Toehead's Avatar
Just a quick question..
To use the Fidle port to control a fan you would jumper C1 (fan) to A2
Is A2 used?
Old 07-21-2009, 07:11 PM
  #123
efi-diy's Avatar
http://www.diyautotune.com/downloads...schematics.pdf
The fast idle output is connected to C1 - A2 is not used.
Old 07-21-2009, 08:56 PM
  #124
Toehead's Avatar
Oh excellent. I was just wondering, as the DIYautotune page states that it is connected to A2.
Thanks!
Old 07-31-2009, 07:51 AM
  #125
GaryW's Avatar
Hi all,
New to the board. I'm using a '7730 ECM on an LA1 3400, so looking for that adapter with keen interest. Any thoughts on using the new microsquirt module: http://www.microsquirt.com/viewtopic.php?t=23315? for this app? I won't need the speedo or cruise functions, but understand that many will. thnx!
Old 07-31-2009, 11:41 PM
  #126
efi-diy's Avatar
Until an suitable method of solving the VSS input issue is found this adapter is a ways off. Perhaps over the winter.
Old 08-16-2009, 07:28 PM
  #127
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Hey guys I'm working on an MS2 v3.0 install on my 88 right now and I've hit a couple snags. I listed them in this thread below if any of you that have already done the install would like to way in and help me out that would be much appreciated.
https://www.thirdgen.org/forums/dfi-...s2-v3-0-a.html
Old 09-02-2009, 01:41 PM
  #128
Colt's Avatar
Car: '89 Formula
Engine: 383 Megasquirt
Axle/Gears: 7.625
Hey guys. Does anyone know if it matters that the donor ECM is a 1228747 or 1227747? I'm not sure what the difference is.
*** OOps, nevermind. I just read earlier in this thread that the 7747 ECU is recommended.*******
Thanks.
Old 09-03-2009, 07:02 PM
  #129
efi-diy's Avatar
Ok so how many people have an install working?
Old 09-03-2009, 11:50 PM
  #130
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
I guess I should introduce myself to this thread. I've been on this site since 1999 but I don't post much. Lately I'm getting some interest back for my car and I've decided to get more serious about it. I've done cam, heads, LT1 intake, headers and maunal trans swap but I never really addressed the ECM. Before I did the trans and intake swap I did have a ""custom"" chip made for me but driveability was never good. So now I'm going to do the megasquirt. A few days ago I finished the install of the LC-1 wideband. Over the last few days I've been driving the car around and watching the AFR's. Man, are they messed up. I've decided to do the TPI adapter board with the MS. I already ordered the parts from DigiKey and it cost about $8 plus shipping. I didn't purchase the Q2 transistor because I have a manual trans. My next move is to order the TPI adapter board and the "7747" donor ECM. I will let you guys know how it goes. Hey Efi-Diy do you work for DIYAutotune?
Tom
Old 09-04-2009, 12:56 AM
  #131
efi-diy's Avatar
Tom
I'm one of their wholesale suppliers.
Old 09-07-2009, 02:05 AM
  #132
WASyL's Avatar
my one is working now without any problem after solving problem with ign. module
best regards
Old 09-08-2009, 06:17 AM
  #133
ScottyRock's Avatar
Car: 92 L98 Z28 Heritage Hard Top
Engine: L98 350 w/ HSR,24lbs inj,AFPR
Transmission: TCI Super Street Fighter W/3300 sta
Axle/Gears: 3.73 Detriot NoSpin,LPW cover
Is a Plug And Play kit going to be comming soon for a 92 L98? I am a compleat retard with wires and wiring, and would like somthing for a 92 L98 350 TPI Z28 Camaro. Thank you sir.
Old 10-04-2009, 04:39 PM
  #134
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
Here's some pictures of my adapter for those who haven't done one yet and want to see more pictures. I'm still waiting for the Megasquirt board.
Adapter with 747 donor ecm side rails mounted
Adapter in 747 case, waiting for megasquirt board
Old 10-05-2009, 07:41 AM
  #135
WASyL's Avatar
how will you lead vacuum hose for MAP sensor which is on a same side as ECM connectro
best regards
Old 10-05-2009, 03:35 PM
  #136
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
I'm not sure. I haven't thought of that yet. I might use the megasquirt MAP for barometric correction and then rewire the leads for the MAF to a MAP mounted on the intake.
Tom
Old 10-06-2009, 01:07 PM
  #137
Socalz's Avatar
Car: 85 IROQ
Engine: 5.7
Axle/Gears: 10 bolt 3.42
I also have one that works. I cut a hole into the ecm case and firewall for the map line. Also had to set the ignition output to falling edge.
Old 10-07-2009, 01:26 AM
  #138
kaosanddoom's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7
Axle/Gears: 3.43
is there any one that sells this already assembled with adapter board in place. i would love to switch to mega squirt, but soldering boards together and such is not my thing, me and electrical stuff, blech.
Old 10-07-2009, 09:49 PM
  #139
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
I can see where it can seem intimidating but assembling this board is really a piece of cake. Just make sure you have a soldering iron with a small tip and some small diameter solder. Like someone else said, the hardest part is liberating the donor ECM connector. I used a solder sucker tool and desoldering braid.
Old 10-10-2009, 04:52 PM
  #140
83 Crossfire TA's Avatar
A small propane or butane torch will let you heat all the pins at once and just pop it off in a few seconds...
Old 10-30-2009, 10:04 PM
  #141
efi-diy's Avatar
I usually install the MAP sensor on top the MS 3.0 main board and drill a hole to get the line in. Just make sure you use 2 wire ties to stabilize the hose as the MAP sensor can't be screwed to the board.
Old 11-03-2009, 02:51 AM
  #142
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Keep us updated on the adapter for the 90-92 TPI Cars!!! Looking forward to that!
Old 11-08-2009, 12:30 PM
  #143
efi-diy's Avatar
The amount of design time for the 90-92 TPI is quite a bit higher than the '165 due to the VSS issue. If someone was to set up a group buy with say 20 orders, it show there is enough interest in the adapter to invest the time needed to do the design.
Over to you....
Old 11-08-2009, 12:49 PM
  #144
Street Lethal's Avatar
If someone was to set up a group buy with say 20 orders, it show there is enough interest in the adapter to invest the time needed to do the design. Over to you....
Count me in, so I guess that makes one....
Old 11-09-2009, 02:13 AM
  #145
WASyL's Avatar
+1 - for my camaro
best regards
Old 11-09-2009, 11:40 PM
  #146
efi-diy's Avatar
Another approach would be to feed the VSS into a GM DRAC module to run the speedo rather than have the adapter board take care of this function.
Comments.. ?? It would mean wiring up the DRAC module separate from the MS install.
Old 11-11-2009, 12:02 PM
  #147
ScottyRock's Avatar
So does this mean I could run MS II in my 92 L98 Z28. I was thinking of trying the Dakota Digital module with MS II. I am doing a 400+ small block this winter and keeping FI. Anyone done this or somthing simialar with the SD Camaros.
Old 11-11-2009, 12:09 PM
  #148
ScottyRock's Avatar
Over to you....
100% in for a group buy on the 90-92 TPI adapter board.
Old 11-11-2009, 05:39 PM
  #149
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
I have an 870 ecm I would like to convert to megasquirt will a 746 ecm work with the adapter board?
There are already post about repinning to convert the 870 to a 165 that is ok to me. I would like to use the 746 ecm I already have as the donor for the adapter board.
Old 11-11-2009, 11:58 PM
  #150
efi-diy's Avatar
The '746 will work just fine as the donor for the connector and case.
Quick Reply: NEW adapter board for megasquirtII to 86-88 tpi cars
