TMS 2532 Prom
Old 08-13-2012, 06:51 AM
61Airstream's Avatar
TMS 2532 Prom
Is the TMS 2532 the correct eprom blank to burn one for the 1228079 ECM?
Jim
Old 08-13-2012, 07:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TMS 2532 Prom
Not exactly, although it may work as the pin out is different then the 2732 EPROM. The reason I say this is that the 2732 EPROM can be used in place of the stock PROM by moving some of the pins around via an adapter.
The stock '8079 PROM is 1K x 8, while the two mentioned here are 4K x 8.
I looked for the 1K x 8 PROM pin out but can't find it. It is also a one time device.
RBob.
Old 08-13-2012, 08:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TMS 2532 Prom
A follow up. If you have a stash of the TMS2532 EPROMs you may be in luck. The data sheet for it states "pin compatible with existing ROMs and EPROMs (8K, 16K, 32K, 64K)."
The 8K ROM is what is used in the '8079 ECM.
RBob.
Old 08-14-2012, 04:02 PM
Re: TMS 2532 Prom
Thank you, what about TMS2708JL that have been erased? It seems that there are people out there that can burn these, but just don't have the blanks. I'd like to get a couple burned for my recent crate 350/ 300 hp install. One with EGR and one with it deleted.
Jim
89-IROCZ-5.0TPI
02-22-2022 09:26 PM
Linson
09-25-2021 07:55 PM
dusterbd
09-29-2015 08:40 AM
BLK87Z
09-18-2015 11:29 PM
Winchester1094
09-15-2015 09:48 AM
Quick Reply: TMS 2532 Prom
