Commanded AFR vs wide band measurements
I don't have a wide band (yet)...
But I was curious about folks who do... what kind of correlation do you guys get between the commanded AFR and what the sensor actually reports?
Is it pretty close? Way off? Way off in the lean direction? Rich direction?
Re: Commanded AFR vs wide band measurements
Not sure how to answer. EBL-ECU. I idle OL at 14.5-14.9/1. It moves around day to day or stop sign to SS. Off idle I get some TF fuel on a slow acceleration and it goes to about 13.5/1 or so. I accelerate briskly AE pulls it down to 13.0/1. Now I am OL until 12 MPH last I checked. Over 12 MPH(maybe 15 I forget) I am CL at stoich.
If your question is on PE 0-2000. My A/F is gear based(manual) so it starts at 13.0 in 1st and increases to 12.5 in 4th. I am seldom in 4th for PE as speeds(3.07) are excessive on XWay.
I am TBI by the way until next month port fuel finally happens(Edelbrock 4B TB 1000cfm/World SP) .
no green
01-09-2016 09:22 PM
