xdf file
xdf file
Can someone link a site I can get the latest xdf file and adx file for using tunerpro. I tried code59.org and cant get it to register someone has already used my email address it says . I'm just starting out trying to tune my car and I looked at all the stickies and didn't see a answer to my question.
Car: check
Engine: check
Transmission: check
Re: xdf file
I have some BINs and such from Code59 too. The one thing I'm not sure of is the various versions. Some XDF won't work with Tuner Pro V4, only V5, which makes sense as Mark did change the formatting of the XDF file for V5.
Then there is the Code59 BIN versions. For example here are two different XDF files:
Code59_3Bar_1.3_V18.xdf.zip
Code59_3Bar_1.6_V25_TP5_ONLY.zip
There are two version numbers in each. The first I believe is the XDF file version number, while the second version number is probably for the BIN it is to be used on.
RBob.
RBob.
