What EEPROM is better for a 1992 305 firebird?
Car: Pontiac Firebird 1992
Engine: 191 V6 3.1
Transmission: Automatic
Hi everyone! I have a 1992 3.1 V6 Firebird and I am going to programming my PROM, one of my friends is using this:
Atmel AT29C256
http://www.ebay.es/itm/1PCS-IC-AT29C...item21004f6443
But I have read in this forum that the appropriate one for the 92 V6 191 is the 27C256:
http://www.ebay.es/itm/OTP-PROM-27C2...item53e2986565
I have the opportunity to get first ones cheaper than second ones.....
What would you do?
Thanks!!
Atmel AT29C256
What would you do?
Thanks!!
Car: check
Engine: check
Transmission: check
Re: What EEPROM is better for a 1992 305 firebird?
Atmel AT29C256
But I have read in this forum that the appropriate one for the 92 V6 305 is the 27C256:
What would you do?
Thanks!!
Atmel AT29C256
What would you do?
Thanks!!
The AT27C256R is a OTP device. OTP being One Time Programmable. After that it gets tossed and another one programmed.
The '92 3.1l Firebird ECM does use the '256 kb PROMs. It is about 191 CI in displacement.
RBob.
Engine: 191 V6 3.1
Thanks!
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
