Cant connect to aldl port
Car: 1986 Camaro
Engine: 355 tpi
Hey guys, im having some trouble trying to connect to my aldl so i can datalog and send for tuning, but my computer wont connect to it? My computer wont download the driver and im not really sure what to do..
Re: Cant connect to aldl port
Subscribed...
I know cables need to be specific and some require drivers...
I did have an instance where I could connect to my 91, but it would not connect to my neighbors 89... could not figure out why (after it was clearly working on my 91)....
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
86 through 89 TPI use the 165 ECM which is said to be problematic in it's connections. The 90 and 91 use the 730 ECM which is much easier to connect. IIANM, I recall reading that some 165 will connect without the 10k resistor or possibly, once connected, you can remove the 10k so the ECM will go into closed loop. Try a search for 165 ECM connection problems, maybe someone has come up with a solution or a reliable cable. HTH!
Car: 1986 Camaro
Engine: 355 tpi
I'll look into it thanks! I'm also running the Delco 16198259 ecu, does that make any difference in regard to connection problems?
Car: 88 convertible
Engine: 5.7L
Axle/Gears: 3.07
I believe the 259 is just an upgrade of the 165 but has the same basic design, the same connection problems though.
Car: 1986 Camaro
Engine: 355 tpi
Well I got my laptop to recognize the moates cable, but it's still telling me that there's no signal from the ecu?
Is there something I could be doing wrong with datamaster? I'm no good with this stuff..
Car: 1986 Camaro
Engine: 355 tpi
Ok i downloaded winaldl and im able to get readings from the ecu through that. Whats the deal with datamaster? I must be missing something. I have the port to com3 and it still doesnt give me anything
Car: 88 convertible
Engine: 5.7L
Axle/Gears: 3.07
Sorry, I am not familiar with Datamaster so really can't say one way or the other. Maybe someone familiar with it will chime in. GL!
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
I would recommend that you go with turner pro RT. I have had good luck with that program. With the 165 ecm, connecting can be a problem but I have had good luck with it.
Car: 1986 Camaro
Engine: 355 tpi
I have tunerpro rt downloaded as well but I'm not having any luck :/ I had luck with a different program though but each time I try datalogging it doesn't save the log...
Transmission: 2004r
I would still recommend Turnerpro Rt version 5.0. If you have the com port configured correctly and other settings correct, it works pretty good. I'm running windows 10 and tunerpro RT v5. I can datalog for about 15 minutes before it gets errors and disconnects. I can save the log and play it back, but I admit the 165 ecm can be problematic at times.
broke91firebird
03-01-2016 08:33 AM
