IROC ignition woes
Car: 1987 Camaro IROCZ/28
Engine: TPI 383"
Transmission: TH 350
Axle/Gears: 10 bolt 3:27
IROC ignition woes
My '87 IROC Z/28 is mystifying me. I turn the key on to start it, and NOTHING happens. All lights work, radio & htr works, ignition buzzer works, wipers also. I go to the "start" position, and nothing. What gives??
If everything works except the starter, then it is possibly bad.
Will the starter crank if you jumper the "s" terminal on the starter
solenoid to the positive cable on the solenoid with a screwdriver?
Do you have 12V. at the "s" terminal when the key is turned to start, but the starter doesn't spin? If so, the starter is most likely bad.
ambainb
04-25-2016 09:21 PM
mustangman65_79
08-11-2015 03:17 PM
