Car wont start
Old 03-07-2008, 11:26 AM
wconn1979's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Car wont start
My car battery died and I jumped it off with my truck I hooked my cables on the truck up and someone else hooked up the cables on the car and did them backwards. It burn a wire beside the battery. after repairing the wire the car still would not start, it was not getting spark so I changed out the Distributer, then it wasnt getting fuel so I changed out the Fuel pump. The car is still not getting fuel with the new pump. I changed out the ECM still nothing so now I am scratching my head.
Car is a 92 Camaro RS 305 TBI.
Old 03-07-2008, 12:00 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Re: Car wont start
OK have you tested the battery? Tested the alternator output? Checked your fuses?
Does the starter activate when you turn the key?
Old 03-07-2008, 10:34 PM
wconn1979's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: Car wont start
Battery is fine, why would the altenator keep it from starting and I have checked all fuses. The starter turn the car fine just not getting fuel past the TBI.
Old 03-08-2008, 12:20 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Re: Car wont start
Wasnt sure if you had it tested...if you had a major short like that it should be tested.
Do you hear the fuel pump prime when you turn the key (I'm not sure if the TBI pump does this)? Do you have power to the fuel pump? Check the fuel pump relay, check all your fuses.
Wade787b
09-29-2015 01:15 PM
TheExaminer
08-26-2015 04:59 PM
86Base
08-08-2015 01:34 PM
L98GTA87
08-05-2015 11:02 PM
Quick Reply: Car wont start
