instrument cluster issues
Old 04-25-2015, 08:10 AM
92purpz28's Avatar
Car: 92 camaro z28
Engine: 305 5.0 tpi
Transmission: auto 700r4
Hey everyone I need some input with a strange issue. My cluster is acting strange. If I tap on the dash it makes the tach jump around and if I tap hard enough the airbag light will come on then go off. The speedo and odometer don't work either. Is it a short somewhere? Is it worth having refurbed or should I just go ahead and get a Dakota digital setup?
Old 04-28-2015, 04:47 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Dash 4 Cash
You might have a loose ground or dirty / loose connector in back of the dash.
Check those easy ones first.
If you are convinced they are OK then you can take your dash to a refurbisher.
It’s up to you if you want to retain the stock look of your dash or switch to the Dakota.
Happy Racing !
After The Fourth Barrel Roll I Lost Control Of The Car
TheTraut88
09-11-2015 05:16 AM
Fronzizzle
09-08-2015 12:10 PM
Accerrito22
09-05-2015 09:34 PM
!CamaroDave
Members Camaros
09-05-2015 10:39 AM
andy74
09-03-2015 08:41 AM
Quick Reply: instrument cluster issues
