1987 firebird formula 350 has no electrical power
Just got the car as a project got it home one day had power lights dash park lamps next day went out to tinker had no power at all alternator was checked its good new starter maybe feasible links need help solving this problem I'm new to this forum just joined
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fusibility Feasibility
The most likely cause of your problem is a loose, dirty or defective battery cable connection on the + battery cable at the starter.
Happy Racing !
The Steering Turns Real Easy When The Car Is On The Roof
Happy Racing !
Received 1,672 Likes
Re: 1987 firebird formula 350 has no electrical power
Yup, start at the batt and work your way toward the loads...
Batt cables (both, at both ends), and fusible links, are the most likely. Use your meter and find where the voltage changes from 12.x to 0.
