left over t56 swap parts and engine
Old 03-19-2008, 11:08 AM
90IROC305's Avatar
Car: 1990 IROC-Z
Engine: lb9
Transmission: t56
I have a spohn crossmember and torque arm for an aftermarket t56 or a t56 with
an adapter plate for a t5 bellhousing. - $350
I also have a driveshaft for the same setup. It is a spohn extreme duty. - $300
a t5 that is in need of a rebuild out of a 90 iroc- $100
t5 crossmember- $50
and i have a tbi 350 out of a 88 half ton pickup. It supposedly has around 114,000 miles and still ran when removed, truck was hit and totalled. has complete wiring harness, all accessories are removed but i still have them and will sell seperately if someone is interested. trying to get $300 for everything. just need it out of my garage. would like to have picked up.
Old 03-19-2008, 11:12 AM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
Re: left over t56 swap parts and engine
Which u-joints is the driveshaft set up for. Standard or 1350? And what is the differance in the driveshaft, between the one for the stock T56 and the one with the adapter plate? (length?)
Old 03-20-2008, 10:03 AM
90IROC305's Avatar
Car: 1990 IROC-Z
Engine: lb9
Transmission: t56
standard u joint. it is 2" shorter than a stock driveshaft
Old 03-20-2008, 11:32 AM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Where are you located?
Old 03-21-2008, 02:37 PM
90IROC305's Avatar
Car: 1990 IROC-Z
Engine: lb9
Transmission: t56
northern virginia
Old 08-19-2008, 08:46 AM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
If you still have this set up let me know. Got the trans ready to go in and need the DS and mount. Send me PM or email.
BlackphantomZ28
LSX and LTX Parts
10-19-2015 06:25 PM
jharrison5
08-19-2015 05:53 PM
bradleydeanuhl
08-12-2015 11:48 AM
1992 Trans Am
08-08-2015 08:16 PM
1nastygta
08-08-2015 07:38 PM
Quick Reply: left over t56 swap parts and engine
