FS: Rodeck Aluminum Gen 1 Block
Old 08-31-2015, 10:33 AM
C409's Avatar
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
....... For Sale ..... A Rodeck 350+ Aluminum SBC Block ... 4.137 bore 400 main journal size ... the block had some damage in the 5 + 6 rod case from a connecting rod that let loose some time ago ... that part of the block had been successfully repaired and new sleeves installed ... however when the block was pressure tested , it was discovered to have water leaks from Cylinders 1 , 2 and 8 and I decided to go a different route ... the repairs done cost about $1000 and that is what I am asking for the block plus shipping ......... you can have the water leaks repaired or if you drag race you can hard fill the block and run without coolant ... being sold as-is ...... $1000.00 plus shipping .......
Old 09-01-2015, 03:36 PM
C409's Avatar
Car: '87 Vette C4
Re: FS: Rodeck Aluminum Gen 1 Block
Old 09-01-2015, 03:40 PM
C409's Avatar
Car: '87 Vette C4
Old 01-21-2016, 03:45 PM
C409's Avatar
Car: '87 Vette C4
........... BUMP ............
Old 01-21-2016, 04:09 PM
Twin_Turbo's Avatar
where are the leaks coming from? cracks or around liners? main caps included? cam journal size? lifter bore size? Looks like it's dry sump only
Old 01-21-2016, 08:29 PM
C409's Avatar
Car: '87 Vette C4
..... The water is coming from behind the sleeves , no cracks were found . Main caps and bolts are included . STD SBC cam size and location . Lifter bore is .842 ... std SBC . Its definitely an external pump only ... can go wet or dry sump ...........
midge54
12-27-2019 04:14 PM
1992rs/ss
16
01-28-2016 09:58 PM
Reddeath210
10-06-2015 08:20 AM
transam84
Exterior Parts for Sale
08-14-2015 08:54 PM
Quick Reply: FS: Rodeck Aluminum Gen 1 Block
