[CA] 82-92 NON AC STANDARD HEATER BOX + MOTOR (SOLD)
(((((SOLD)))))Hello All,
I have a nice original pressed steel non ac standard heater box and motor here for sale.
Has the original paint on it with just a couple minor areas with rust that can easily be sanded down and repainted if needed.
Motor has been bench tested and works.
Good rubber seal.
Comes with all factory mounting hardware.
I also include about 6" of wiring plug for testing purposes, if your simply swapping out your old AC box on the firewall, then all you have to do is swap in the old AC resistor, keep your wiring intact and everything except your AC and 4th HIGH blower speed will function.
$129.00 (plus shipping)
Pay Pal and Money Orders accepted.
Please contact me here or at (contact.thirdgenusa@***.net) for availability and shipping quote/ payment instructions.
Thanks for looking!
Dave Staubli, formerly IROCZDAVE
Good rubber seal.
Thanks for looking!
Hi speed will work with oem wiring. Just have to mount the hi speed relay somewhere. Thats how I have it on all my cars using factory non ac boxes and blowers
Just swap out the resistor bridge. You may have to file the hole in the box a bit. Factory relay is easily mounted on the box by drilling holes and using factory screws
Very nice unit you have. Would have grabbed it but have a redone spare for future use. Installer should not forget to plug lower unused hole in firewall
GMP318
Carburetors
10-14-2015 08:14 PM
509 camaro fan
10-11-2015 01:52 AM
